SanDisk Sansa e250 MP3 Player
Problem for SanDisk Sansa e250 MP3 Player
Sansa Raphsody 250R 2GB
By verito_2007 on Jun 15, 2007
My mp3 reproducer, it doesn´t start. It just shows the beginning screen that says SanDisk and then other that says Sansa Raphsody then a white screen and all start over again.
It get corrupted since it showed all files with strange names and then I formated the unit, but it is the same.
the unit with volume named 16MB format it's empty
i formatted it too.
I ran the device recovery setup and the same.
After ran the firmware updater but the same.
What do i do?
Solution #1
posted on Jul 23, 2007
Somewhat Helpful)
mikethompson
Rank: Guru  SanDisk Expert
Rating: 86%, 399 votes
It is very dangerous in formatting the 16MB format of the device. After learning it a hard way, i also learned the the 16MB format is a second partition of your player where is installs the firmware of the device. Formatting it will ruin your player and it will never function again the way you want it to work.
Was this helpful?
Yes
No
Solution #2
posted on Dec 06, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I was unable to recover my Sansa e260 with the firmware update, as I got the "Failed to read version details" error message. I tried this and it worked.
1. Enter recovery mode (with the hold button on, press down the voice recording button, and without letting go of it, press ON).
You will get a messaging ironically welcoming you to recovery mode and asking you to plug in the USB.
2. Connect the player to your PC, which ought to recognize the drive as "16MB Format". This is the partition where the firmware is stored.
3. Download the firmware file from here. You can try running it. If it work, great, otherwise, do as follows:
4. Extract the firmware to disk using winrar or similar, and copy the SKU_A, SKU-E folders and the sansa.fmt file to the "16MB-FORMAT" drive. Safely remove drive and disconnect it from the PC. In my case, it displayed a "Formatting" message. When it finishes, it should switch on normally (make sure you've moved the hold switch back to initial position).
Popular Solutions for SanDisk Sansa e250 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa e250 MP3 Player
Do you recommend SanDisk Sansa e250 MP3 Player?
Answer
Answer
I can't turn the player on.the circular ring is lit,but no responce.it is sandisk sansa e250 series
Answer
My ipod wont turn on.The light just comes on when i turn it on
Answer
its not responding to anything. it looks like the screen is on but not responding to anything even... (More)
Answer
there is no hole in my sansa. when i tried to install firmware it is asking to connect my sansa with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For SanDisk Sansa e250 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 441
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
