Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
WHERE CAN I PURCHASE NEW LINE SPOOL FOR RYOBI MODEL RLT-900W
WHERE CAN I PURCHASE A NEW LINE SPOOL FOR MY RYOBI MODEL RLT-900W ELECTRIC.
I stay in Benoni.
  • JOHAN OOSTHUIZEN Jan 16, 2009
    YOU CAN ORDER ANY RYOBI SPARES FROM YOUR NEAREST MICA AND THEY WILL ORDER IT FROM RYOBI (011-805-5540) AT MIDRAND. LEAD TIME TWO DAYS
    I FIXED MY OWN PROBLEM.
    (YOU CAN ORDER ANY RYOBI SPARES FROM YOUR NEAREST MICA AND THEY WILL ORDER IT FROM RYOBI (011-805-5540) AT MIDRAND. LEAD TIME TWO DAYS)
4 Suggested Answers
evwood
  • 50 Answers
SOURCE: RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Posted on Jan 03, 2009
SOURCE: have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Posted on Aug 15, 2009
rycgl
  • 1545 Answers
SOURCE: I HAVE A RYOBI RLT
This is all I could find for that model. Very little info is available on the RLT580, but I am sure you can get the part you need somewhere. Is this unit GAS or Electric?
http://www.ereplacementparts.com/search_result.php
Posted on Sep 05, 2011
How do i get trimmer line holder cap off my electric ryobi trimmer rlt 1038
Hi, I wished I had read this before I bought my rlt1038, I used it for
8 mins and 1) long grass caought around the drive head, 2) I tried to undo the screw holding the line head. Fortunately I have a wide pair of foot prints to go across the line head and a central heating pump adjustable spanner- after 5 mins I had undone it. Yet another bad design !
Good Luck
Mar 16, 2013 | Ryobi 15" Electric Factory Reconditioned...
How to attatch trimmer line to RYOBI ELT400
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, hdy
Jan 30, 2012 | Ryobi Garden
I have a ryobi RWT285DS and the head is not releasing the whire evenly, upon closer inspestion i found the part that the wire is wrapped around is sitting loose. what part am i missing?
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ff
Jan 08, 2012 | Ryobi Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
I HAVE A RYOBI RLT 580. MY PROBLEM IS THAT THE COVER ON THE SPINDLE BROKE .THIS IS THE COVER THAT CLOSES THE LINE AND SPRING AT THE BOTTOM. NEED A NEW ONE. CAN ANYBODY HELP ME
Sep 05, 2011 | Ryobi 15" Electric Factory Reconditioned...
I have an electric RYOBI weed eater and I need HELP...manual/instructions on how to access the spool so I can feed the line through the exit hole and use the thing! Thank you. Have two numbers: EL...
Unscrew thw bump nut to remove the spool. Take a length of about 6 foot of line, kink it in the middle and pass this through the hole in the spool. Wind the two lengths of line around the spool in their own divisions and in the same direction. The direction of wind is embossed in the reel and the line should be wound tightly and held all the while. When you have about 6-8 inches left in your hand, bring the cover up to the spool and carefully pass the two ends of the line through the holes, push the cover all the way over while pulling on the two pieces of line and ensuring that the lines stay on their own side of the division on the spool. Fit and tighten the bump nut and trim the lines to just about the cut-off blade.
The lines should trail out of the holes in the direction of the machine's rotation. Try cut with the tip of the line as much as possible. Cutting nearer the drum flexes the line and will lead to early breaking of the lines. Run the motor at a constant speed and rather move the cutting head in and out of the weeds to affect a deeper cut
Jul 09, 2011 | Ryobi 15" Electric Factory Reconditioned...
Have a ryobi rlt 30 cd and the spool wont spin fast enough
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
Removing line feeder from a Ryobi, model 100
You just pull it off. It takes a lot of force. When re-installing the spool, be sure that the line is inserted in the exit hole and the line is wound in the right direction.
Dec 09, 2008 | Ryobi 15" Electric Factory Reconditioned...
Oct 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
124 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
