Question about Kenmore 24 in. 16293 Built-in Dishwasher
Dishwasher is stuck in the clean cycle. the green light does not stop flashing.
  • 45 Answers
If it has a knob the knobs should pull off. the gear on the back of the knob may not be turning the switch inside. Please let me know if i can be any further assistance.
Posted on Jan 15, 2009
  • 318 Answers
You have a unit that thinks it did not heat the water properly.
so do this, push the option buttons... this will enter the service mode and that will reset the error code you are seeing.
"high temp, air dry, high temp, air dry". push this sequence and then all the lights will light up and allow you to cancel the cycle.
then try the unit again and make sure you dont open the door while it is running.
the unit is looking for a rise in temps during the main wash cycle, there are a few other things that can cause this, but usually opening door or too low of water temps can cause this failure.
now go try this and get back to me if you need more help. tom
Kenmore elite dishwasher stops in mid cycle green clean light flashes 8 times pauses and then flashes one more time
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control.
May 23, 2013 | Kenmore Dishwashers
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwasher says dishes are clean but is still stuck in cycle. tried resetting the breaker but no luck. the green light that goes on when clean is constantly flashing but dishwasher is non-responsive. any...
Some dishwashers have some sort of float switch. They can stick , try rocking dish washer if stuck mid cycle, I would make sure the food collect grid at bottom is clear, try flushing machine through with an empty load now and then, you can buy stuff for cleaning dishwasher insides too.
pete
Nov 08, 2010 | Kenmore Dishwashers
My dishwasher is stuck on clean mode? what can i do to reset? it finished cleaning, then will not cancel. just green flashing light that says clean. i tried to unplug the washer for about 1hr ,but no help.
The flashing clean light is an indication of an error during the cycle. I put together an explanation of this and how to reset the control so you can use the dishwasher again. Follow this link and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 04, 2010 | Kenmore Dishwashers
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher malfunction
BAD WATER SELONOIDE, OR BAD BOARD
Dec 18, 2007 | Dishwashers
Kenmore 24 in. 16293 Built-in Dishwasher Logo
29 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
