Question about SanDisk Sansa e250 MP3 Player
Sansa 250c freezes at SanDisk and the Rat startup screen
This sanza will turn on and off but will not go past the start up screen, won't show the next menu (music, pictures etc). Won't show up on computer when linked with the USB cable either.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 15, 2009
Can't load music onto my SanDisk Sanza Fuze Mp3 player
Itunes is what is known as proprietary software.
Which basically means that it only works with hardware of the same brand. (Apple- Ipod)
You will not be able Itunes to load mp3 files on a Sansa MP3 player.
Aug 01, 2010 | SanDisk Sansa Fuze MP3 Player
ScanDisk Sanza Fuze Manual and Info
You can download the manual from the manufacturer's web site at http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Jul 06, 2010 | SanDisk Sansa Fuze MP3 Player
My sanza fuse mp3 player will not turn on battery
Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
Mar 30, 2010 | SanDisk Sansa Fuze MP3 Player
My sanza has an blck screen an don't work
Plug in your USB cable to your computer and the MP3 player. Then Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
Jan 15, 2010 | SanDisk Sansa Fuze MP3 Player
When I connect my Sanza Fuze to my computer the screen on the player says "Connected" but the device does not show up in "My Computer" Any suggestions
There's a Sansa Fuze support page, see next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
When the Sansa is not recognized by the computer, start troubleshooting using next link:
http://kb.sandisk.com/app/answers/detail/a_id/42
Need more help ? Just post a comment.
Nov 22, 2009 | SanDisk Sansa Fuze MP3 Player
Computer will not read Sansa Fuze
did you try to connect from your sanza to onboard usb don't use the front of your pc usb maybe wrong setup or wrong connecting the wire . use the usb located at back of your pc , if you connect the sanza to you pc if have words appear ( found hardware)it mean the sanza need the software driver and you unable to detect without driver..
Jul 05, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa View doesn't start up
why doesnt screen dont work on these when i start up it turns in a faded screen then it starts again
Jan 09, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa 250c software
It should be available on the SanDisk website in the support section. You could also call them and order a disk for a fee.
Cheers
Dec 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
Mp3
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240''s there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that''s frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately. <>
May 04, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
