Question about Canon DR-7580
Scanner 7580 error P00
Error p00 while initialising
    Problem Solver:
  • 6 Answers
Hi, Change the guidelights the problems will be solved. Samir Dhingra 9820800633
Posted on Jun 05, 2010
Clean the Scanner thoroughly and start doing your work with scanner.
Posted on Jan 15, 2009
Canon DR9080c - getting error code P00 which means paper jam in the scanner but there is no paper in there & I have cleaned all the sensors! What else could this be?
This is a common problem in 9080C. When the top cover is closed, the sensor sends light and it is reflected thro the black cover in the bottom. Then the scanner assumes the cover is closed. Any obstruction is treated as P00 error. You will notice three small oval & round shaped clear plastic. Clean them with a brush and ensure the edges are clean. Light goes thru one side and come thro the other, which is sensed by the unit placed in the top cover.
S. Mohan, India
Sep 12, 2013 | Canon DR-9080C Path-Through Scanner
I have a canon dr-7580 with a P00 error. I've blown it out but no paper found. what next
Use Qumatool to check if all the sensors are working okay. Normally sensors dont fail, there must be a small piece of paper (like the 'dot' of pre-printed stationery) sticking somewhere.
S. Mohan
Aug 31, 2010 | Canon DR-7580
Turn on scanner and POO appears? Help!
If there is already a document inside the scanner while powering on, you get P00. Remove any paper inside the scanner. If there is no paper and you still get P00, then thee must be a small shred of paper blocking sensors. Gently blow air to clear it.
S. Mohan, Chennai, India
Dec 28, 2009 | Canon DR-9080C Path-Through Scanner
C code 00
P00 is paper/document already present in the Scanner and scanner not initialised. You will heat two beeps. Open remove all shred os paper. C01 is cover open, close it firmly
S. Mohan, India
Jun 30, 2009 | Canon DR-9080C Path-Through Scanner
How to get rectify poo error
P00 not (poo) is paper already present inside the scanner, when it is trying to initialise. Open the cover, remove all shreds of paper inside the scanner and if required gently blow with a blower to clean the dust.
Jun 10, 2009 | Canon DR-7580
P00 Error with no paper jam
See this link:
Look for reference to P00 error
http://74.125.47.132/search?q=cache:CSQKZT0GyBEJ:downloads.canon.com/cpr/software/scanners/5080QRG.pdf+DR-5080C+p00+error&hl=en&ct=clnk&cd=1&gl=us
Jan 23, 2009 | Canon DR 5080C Path-Through Scanner
CANNON SCANNER 7580...ERROR P00
Canon error numbers are logical! Error starting with 'P' is paper related. If there is already soem paper inside the scanner while inititalising, u will get this error. Check for shreds of paper in the paper path. (Error starting with 'C' is Cover and 'E' isn Engineer reqd)
S. Mohan, Chennai, india
Jan 15, 2009 | Canon DR-7580
Error P00 on display, no paper jam found
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
Hi have a p00 error on a canon 7580 scanner does anyone know what this is?
The P00 is a paper jam code .
Check if there is any small bit of paper stuck in any of the sensors. Remove the rubber rollers, clean and refit them.
Hope this helps you.
Thanks for using Fixya
SAM ANDERSON
Sep 17, 2008 | Office Equipment & Supplies
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
864 people viewed this question
old marine
old marine
