Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Nead help pleace
I have i saeco digital plus ad it shows on the display ventilate but nothing comes out of the steam nob can you help me peace thank you tamara kidwell
  • kidtami Jan 27, 2009
    thanks
    Problem Solver:
  • 6 Answers
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Posted on Jan 24, 2009
I have a saeco magic comfort coffee machine and the display is showing " ventilate" . I have looked in the manual that comes with the machine and there is nothing about ventilate. can you tell me...
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a solenoid for the water. That would have to be fixed by a service unless you are very handy.
Feb 11, 2011 | Saeco Magic Comfort Plus Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Jul 28, 2009 | Saeco Royal Professional Espresso Machine
The display says ventilate, how is this done?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Mar 22, 2009 | Saeco Trevi Digital Plus Espresso Machine...
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
Ventilate sign on my coffee machine
Dec 15, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
2 messages: descale, and ventilate plus no hot water only steam
descale you need to use special descaler not vinegar vinegar is not strong enought and remove calcium in little piece that might block elsewhere descaler melt calcium 1 part water 1 part descaler fill the water container start machine open side valve for few second turn it off wait 15 minute repeat untill empty after rince very good that stuff is corosif go in thr menue reset the descaler mode and voila !
THANKS FOR USING FIXYA
FROM MONTREAL
CANADA PIERRE
Feb 18, 2008 | Saeco Royal Professional Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
228 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
