Question about Canon DR-7580
CANNON SCANNER 7580...ERROR P00 - Canon DR-7580
  • 490 Answers
Canon error numbers are logical! Error starting with 'P' is paper related. If there is already soem paper inside the scanner while inititalising, u will get this error. Check for shreds of paper in the paper path. (Error starting with 'C' is Cover and 'E' isn Engineer reqd)
S. Mohan, Chennai, india
Posted on Mar 25, 2009
3 Suggested Answers
SOURCE: scanner 7580 error P00
Clean the Scanner thoroughly and start doing your work with scanner.
Posted on Jan 15, 2009
mohanchennai
  • 490 Answers
SOURCE: Error P00 on display, no paper jam found
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Canon DR9080c - getting error code P00 which means paper jam in the scanner but there is no paper in there & I have cleaned all the sensors! What else could this be?
This is a common problem in 9080C. When the top cover is closed, the sensor sends light and it is reflected thro the black cover in the bottom. Then the scanner assumes the cover is closed. Any obstruction is treated as P00 error. You will notice three small oval & round shaped clear plastic. Clean them with a brush and ensure the edges are clean. Light goes thru one side and come thro the other, which is sensed by the unit placed in the top cover.
S. Mohan, India
Sep 12, 2013 | Canon DR-9080C Path-Through Scanner
Canon dr 7580 error code E30
E30 is a Error related to Exhaust Fan. Pls check if the Fan is working, replace if required. If the scanner was used in a dusty environment, the dust can clog the free movement of the blades. It may require cleaning.
S. Mohan, Chennai, India
Nov 18, 2010 | Canon DR-7580
Canon dr-7580 error 32
According to the service manual if 6080 and 9080c cpu/motherboard are interchanged this appears.
Oct 05, 2010 | Canon DR-7580
I have a canon dr-7580 with a P00 error. I've blown it out but no paper found. what next
Use Qumatool to check if all the sensors are working okay. Normally sensors dont fail, there must be a small piece of paper (like the 'dot' of pre-printed stationery) sticking somewhere.
S. Mohan
Aug 31, 2010 | Canon DR-7580
How to get rectify poo error
P00 not (poo) is paper already present inside the scanner, when it is trying to initialise. Open the cover, remove all shreds of paper inside the scanner and if required gently blow with a blower to clean the dust.
Jun 10, 2009 | Canon DR-7580
P00 Error with no paper jam
See this link:
Look for reference to P00 error
http://74.125.47.132/search?q=cache:CSQKZT0GyBEJ:downloads.canon.com/cpr/software/scanners/5080QRG.pdf+DR-5080C+p00+error&hl=en&ct=clnk&cd=1&gl=us
Jan 23, 2009 | Canon DR 5080C Path-Through Scanner
Scanner 7580 error P00
Jan 15, 2009 | Canon DR-7580
S. Mohan
Dec 17, 2008 | Canon DR-7580
Hi have a p00 error on a canon 7580 scanner does anyone know what this is?
The P00 is a paper jam code .
Check if there is any small bit of paper stuck in any of the sensors. Remove the rubber rollers, clean and refit them.
Hope this helps you.
Thanks for using Fixya
SAM ANDERSON
Sep 17, 2008 | Office Equipment & Supplies
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
863 people viewed this question
old marine
old marine
