Question about Dell F3534 Touchpad
How do solve my touch pad problem is not working.and i have press f7 and fn
  • DEKR
    DEKR May 11, 2010
    are you saying you need to press fn/f7 to get the mouse pad to work
    if so what type of pc is it
    Sergeant:
  • 270 Answers
Send it to the service center.
Posted on Jan 15, 2009
My touchpad has been disabled and im mad at it how do i enable it
it is usually a function key - not sure which on the Dell but look for a blue icon hat looks like a finger over a pad - that is the one - so press the fn key and that key together - will enable it if it is disabled.
on Acer is is fn F7 - may be the same on the dell
Dec 14, 2010 | Dell F3534 Touchpad
My touch pad mouse has stopped working - its not broken but maybe i used a function key??
hello press the function key and F7 key to reactivate your mouse pad if it is not broken other wise check your pointing devices in the control panel menu good luck
Dec 09, 2010 | E-Machines AAFQ50400000K0 Keyboard
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
CAn you please tell me how to switch off the 'mouse' on the computer itself. I know I am supposed to press the "funtion key" and another one in the top two rows, but I am not sure which one. Is it the key...
if im not wrong....its Fn+F7.........
you will find a finger symbol in that key....you need to press Fn and F7 together....it it doesnt works then press F7 alone....
Apr 20, 2010 | Dell Latitude D800 Keyboard
My my touchpad doesnt worrks
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, option here to Disable,
Feb 23, 2010 | Dell F3534 Touchpad
Im using a DELL LATITUDE D620 the touchpad isn't working and one day I found out I have to +ALT to move my cursor on the touchpad,anyway to fix this ?
Looks like you may have inadvertently pressed the Function (FN) key associated with the touchpad. try re-enabling it by pressing Function(FN) and the corresponding F key. For my computer it's F5...but on others it has been F7...just look for the symbol that looks like a touchpad. This should cover it. (: Good Luck!
Jan 26, 2010 | Dell F3534 Touchpad
My acer extensa 4630z laptop's keyboard is not working mouse pad left and right click buttons work fine. I tried the fn f7 buttons but nothing works any ideas? The buttons worked fine yesterday.
try blowing out the dust and particles from under the keys. Are you in NumLock, if so hold the "fn" button down and press your F11or which ever F key says NumLk on it , that should unlock the keyboard. Depending on the age of the unit it is possible that it just may need replacing.
Dec 21, 2009 | Keyboards & Mice
Acer keyboard and touch pad doesn't work
I had the same problem. Do not put the battery back. It is damaged. You need a replacement. It is a battery surge that causes this behavior.
Sep 07, 2008 | Acer NSK8458AN Keyboard
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Keyboards & Mice Logo
35 people viewed this question
Top Dell Keyboards & Mice Experts
 Larry
Larry
Lawrence Oravetz
Are you a Dell Keyboard and Mice Expert? Answer questions, earn points and help others
