Question about 2wire 2700HG-B Router (2700HGB)
No wireless connection
I don't see a wireless settings tab in my 2wire home page or under home network tab.
It's a 2wire 2071-A.
Child got into the wires behind computer and disconnected the wireless and I no longer have the directions can you help me?
Posted on Jan 16, 2009
Trying to hook up internet and computer is aking for a keycode
a key code or Serial is usually on the router in the back or under its that white or yellow (sometimes other) sticker with a long number it will say serial or key-code there. it is sometimes also located on the manual
Feb 04, 2011 | 2wire 2700HG-B Router (2700HGB)
Where and how do i find my access point I'am trying to set up a wireless internet connection
Hi Kregerbc,
If you want to know your Access Point it is the Name of your Network or Network Key (SSID). Usually the Network Name of 2wire router is 2WIRE and the Last 3 digits of the Serial Number of the Router. The Serial Number is located at the side of the router you will find a Sticker and look for the Serail Number you can also see there the Wireless Network Key under the Bar Code. Another Procedure to find the information of the router is to access it. listed below are the steps on how to access the router.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your Wireless Connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya.
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
I was trying to manually the router up as wireless.
If you want to connect to the router wirelessly you need to know the SSID or the Name of the Router (Nework Name) and the Network Key or Wep Key. The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Here you will be able to fine the setting for your wireless connection
  • Connect to your SSID by clicking on START then click on Connect To, Select your SSID then it will ask you for your Network Key. Type the Network Key then hit Connect
Jan 31, 2011 | 2wire 2700HG-B Router (2700HGB)
Need to find my wep key for my AT&T 2 wire 2700HG-B DSL router
Jan 31, 2011 | 2wire (2701HG-B) Wireless Router
I DO NOT KNOW MY SECURITY PASSPHRASE
n most cases the default wireless settings are sufficient for normal home use.
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | 2wire 2700HG-B Router (2700HGB)
Wep address
Jul 01, 2010 | 2wire 2700HG-B Router (2700HGB)
Whats the passphrase for 2wire269?
the passphrase of your 2wire if still not yet personalized it, it is the number in a bracket just below the serial number. it always has 10 numbers
Jun 29, 2010 | 2wire 2700HG-B Router (2700HGB)
Forgot password to log on for my wireless connection trying to add my Wii and now cant even get my laptop back online
You can check the passphrase when you access the router page:
  • If the Wireless Security Key uses the default, the Passphrase is the 10 digits located underneath the router under the S/N.
May 13, 2010 | Computers & Internet
My wireless light will not come on even if i turn the switch on... why is that?
I experienced this same problem on a friend's AT&T 2WIRE 2701HG-B router. The primary computer used WinXP,sp3; I added a laptop, WinXP,sp3 and a Macbook Pro w/ Leo OS v11, successfully.
How to resolve the issue (rather, how I resolved this issue):
From the desktop computer, connected to 2WIRE:
1) Open a browser and type http://gateway.2wire.net or http://192.168.1.254. This site will automatically detect your settings and provide the necessary info., required to set up your wireless network.
NOTE: NTWK information/settings for THIS router can NOT be retrieved via traditional methods. Ignore all other information that assigns a name to your network and/or password. Follow only this wizard, for success in setting up your wireless connection.
2) Verify that your Firewall and System settings are correct and up-to-date. If not, update your software by pressing the link on the right.
3) Click the Home Networking tab (at top of page):
Locate @ the right of your screen, "Status at a Glance".
Under "Home Network", verify:
"Ethernet = x"; (where x = $1)
"Wireless = 0" (ZERO IS OKAY!)
("Zero" will change to "1, 2, 3, etc.," upon successful connection of ea. new wireless device(s) added to the NTWK).
* Once a new wireless device is initially and successfully connected to the NTWK, the LCD wireless indicator of the router will illuminate green.
4) Under "Wireless Settings":
NOTE, the network name. This is the name (of Network) that you will use to connect your wireless device(s).
The default password is the 10-digit number [in brackets] displayed on the sticker, located on the bottom of the router (directly above the UPC code, below the SN).
5) Click "Edit Settings":
In the DEVICE YOU ARE ADDING, click or type in the name of NTWK, as stated under "Wireless Settings". Next, type in the 64-bit WEP password (10-digit number displayed on the sticker, located on the bottom of the 2WIRE router).
6) Click "Verify your Home Network".
Verify the wireless device you added is displayed and has been added to the NTWK.
The Ethernet setting should still remain = 1 (or however many devices are connected to the INET via wire) and Wireless should = 1 (or more, if +1 device has been added).
NOW, the wireless LED shall be glowing the same pretty green, as all the other indicators on the router! You are now connected. Congratulations!
RP
Feb 17, 2009 | 2wire 2700HG-B Router (2700HGB)
2 wire
Feb 08, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
96 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
