Question about Gateway FPD2185W 21 in. LCD Television
Gateway fpd2185w capacitor fix question
I saw the comments on the site and i was wondering if someone could please answer a few questions for me .. my monitor began to not power on just flashing the blue light and the gateway logo ..well after reading the suggestions on the site i took my case apart and have found two of the capacitors to be bulging at the top .. i have just two questions ... one is... would it be ok to just replace these two bulging ones or should i replace all 8 ..and then question two ...as i havent done any soldering before do i need to put the soldering iron on the two points underneath the old capacitors to melt the old solder off and then add new solder to connect the new capacitors or is there another way to remove the old solder. thanks for any help
  • martyj125
    martyj125 Jan 17, 2009
    dude thanks ltfrc i got it working it is the capacitors ...Alan Alan wtf are you talking about man ..displays arcing my arsehole .. it is these 8 capacitors ...dude it works just replace the 8 capicitors and it workdks like new for under 25.00 **** gateway those corporate ***** scum ..this was obviously their pig scum plan release a product an overpriced product mind you but yet let it have a failing component in this case the power capacitors ..these fuckscum knew this and let it happen so you would keep buying monitors ..please someone start a class action lawsuit because i bet you any money this **** flawed **** isnt just hitting this product think about it ..these mofos are pulling some serious scammer illegal ******** ...lets get on top of this while we can ..power to the people
    Guru:
  • 196 Answers
To take solder off you can get some cross wire called DESOLDER this copper wire soaks up the old solder, by heating this new desolder the old solder will jump into it and clear your way. I like the Techspray #3 no-clean model 1822-5f
and its made in the USA!
Posted on Jan 24, 2009
    Sergeant:
  • 227 Answers
Very important, use a pencil iron only, you can destroy the film on the board if you use too much heat. Go for the two bulging ones first. After you remove the capacitors if the holes fill over use a straight pin or similar to open the hole to accept the new part. Also whatch for the polarity on the one you remove, should have a + sign on one side. Make sure the new one goes back in the same way.
Posted on Jan 15, 2009
It is not the capacitors in these boards, The displays are arcing, Class action lawsuit in progress.
Posted on Jan 17, 2009
I have a Gateway FPD2185W monitor with a NVIDIA Gforce 9800 GT. Software was delivered with this monitor to suppor the Pivit features. I have had a few problems with IE since that time, but nothing I could...
The Pivot software is part of the EzTune application. When you installed EzTune, it automatically configured itself with your currently installed drivers. When you update your video drivers, Pivot must reconfigure itself. This is normal operation.
EzTune version 1.4 and later is compatible with Windows Vista.
The latest version of EzTune can be downloaded from the following Web site.
http://oem.portrait.com/dtune/gwy/enu/upgrade.html
Hope that helps...
Apr 11, 2010 | Gateway FPD2275W LCD Monitor
Gateway fpd2185w stopped working and will not show a screen
Check power supply capacitors for bulging top, replace them with PANASONIC FM or FC series from digikey.com
See pictures here: http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2185/
Oct 29, 2009 | Gateway FPD2185W 21 in. LCD Television
Blade tilt very stiff. It appears that the teeth on the hand wheel are worn how do I replace it
I don't know what saw you're using, but normally these worm gears don't wear out, but instead require lubrication. Blow the dust out first with compressed air. Then use simple 30wt oil, in an old fashioned squirt can, and work the saw back and forth a few times, getting oil all the way across the teeth on the trunnion if possible. That does wonders on my powermatic. You may need to squirt a few drops in where the trunnion moves on its races, and whereever you see moving parts bearing against one another. But that's all it takes.
We'd have to know the make and model to suggest replacement parts, I'm afraid.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 25, 2009 | Saws
Help me please - Gateway FPD2185W
Ok, I have some news on this that I know you will not like, but the whole point of this site is to try and help you fix the problem, or at least, try and point you in the right direction.
The news:
I have done some extensive searching on this problem over the last month, as I have also had a friend with a similar problem that you are describing. There is a manufacturer's fault on the main power board, this has been recognised by Gateway, but as it happens inconsistantly (it may happen after a few months or a few years), they are not prepared to recall the product.
Obviously this doesn't help us as consumers that buy their products. The blue screen that you describe happens with alot of visual hardware inc. graphics cards that affects the whole market, and has now become affectionately known as The Blue Screen Of Death (BSOD).
If you are one of the lucky one's, and it is still under the manufacturer's warranty, get it sent back asap, and ask for a replacement to a similar model. If not, the only thing you can do is get it repaired or get a new/2nd-hand one.
Like I said, I'm sorry this isn't the news you wanted, but I didn't think it was fair for you to hang on.
Regards
Tim
Dec 08, 2008 | Gateway FPD2185W 21 in. LCD Television
FPD2185W Gateway monitor
If they dont due anything Contact Monitor Depot Link was below BBB they fixed mine for 99.95 works great Let me know how it turns out
Oct 24, 2008 | Gateway FPD2185W 21 in. LCD Television
FPD2185W Gateway Monitor
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Trying to fix lcd Gateway Monitor.
There's a couple capacitors you need to replace. On the video board, not the power supply board. There is (3) 470uf16v on the video board. They have to be the smaller ones, you can not use the larger ones (they will not sit flush onto the board) Any questions, e-mail me at Andrew@CreativeAudio.biz
Jul 04, 2008 | Gateway FPD2185W 21 in. LCD Television
Gateway FPD2185W take apart
you have to be very gentle and pry it apart.... VERY gently. Any questions you can e-mail me at Andrew@CreativeAudio.biz
Jul 01, 2008 | Gateway FPD2185W 21 in. LCD Television
Monitor Will not come on anymore
I and many many many others like you have the same problem. The suggested solution is to replace the capacitors on the board. (look for the "blotted" ones). This may be too complicated for most and should NOT cost more than $75. BOTTOM line: DON'T BUY THIS MONITOR AND DON'T BUY ANYTHING FROM GATEWAY!
Jan 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
1,921 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
