Question about RCA Televison & Video
Rca hdtv wont turn on
When the power button is pressed, the green light comes on like it is going to turn the tv on then it clicks and turns off, it does this 3 times and will not turn on. this has been an issue in the past but with diligence we would keep pressing the power button until it stayed on, in the last 24 hours, it will not stay on at all no matter how often we try
  • RCA Master
  • 8,617 Answers
You need a new flyback and a CP150 Capacitor. If your chassis is the ITC222 you need flyback number 259296 you can get replacement flyback and the CP150 at the following link and they send detailed photo instructions so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2009
Rca Tv wont power on HD61W66
Sounds like the capacitors on the deflection power board CP150, CP120 and CP114 they are famous for failing in all versions of the ITC222 chassis. You can get the repair kit by that same name from www.tvrepairworld.com the kit has the caps and the cd with repair instructions
May 18, 2012 | RCA HD61W66 61" Projection HDTV
My tv wont stay turned on. It comes on then turn of comes on the turns off
I press the power button it blinks green and attempts to come on three times but it never comes on
Aug 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV - problem turning on
It's on but you are on the wrong input. check your connections from your sources ( i.e. dvd, vcr or satellite/cable box) try pressing source or input button on tv remote
Jul 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY TV WONT CUT ON
Coming out with a silly thing here, have put pressed the TV button on the Hand Controller for it
Jan 27, 2009 | RCA HD52W59 HDTV Projection Television
Won't turn on
I have the same problem; I push the power button green light comes on tv clicks but doesn't come on.
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
