Question about Frigidaire GLTR1670A Front Load Washer
SEtup.. on final spin it "walks"
So I just bought a 3.5cu ft frontload washer and after leveling it and all that jazz it spins out of whack( ie walks on the floor and an err code) develops. I didnt take out the shipping plugs as I really didnt think this was necessary as far as operation is concerned, is it?
  • 318 Answers
100 percent absolutely needed. this unit has alot of power and energy when it goes into the final spin. it will get up to about 1,000 rpms and that needs to be contained by the shocks and suspension.
without removing the shipping bolts this unit wont be able to be used.
but the good thing is it will only move about 5 feet as then it will pull the plug out of the wall!! LOL
take out the bolts and plugs and then it should work well for you.
Posted on Jan 15, 2009
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Samsung washing machine wobbles on spin.
The feet of the machine have to to be leveled. When reading the instructions, leveling is important for the very reason you are having difficulties.
Sep 19, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer spin cycle error
This is a common problem, check to make sure machine is level an not on a lean, also check the machine feet are all wound down so machine sits firm.if all good then it may be worn out suspension rods
Sep 26, 2017 | Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam...
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The machine is level but the drum spins as if it were not. loud and the machine moves forward
These new front load machines are much heavier and spin much faster than the top load machines. If you have old wood floors in your home or you live in a mobile home, the machine may tend to "walk" or vibrate on the floor. You can try putting something under the machine to help prevent it from walking as it is spinning.
Feb 23, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer is 5 years old and making alot of noise during final spin
these frontloads are notorouis for having their rear bearing go out... if machine is all level and service told u the tub is bad then i would probably agree.... most of the newer frontloads had a 5yr parts warranty on the tub.....thet rear bearing is actually built in to the rear outer tub so replacing requires allot of labor as one must teardown unit and remove both drums and seperate and install new parts.... i would check your warranty for ur specific options,,, hope this helps
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Model p801 frontload, it walk all over when in
sounds like your machine is unlevel have you taken a level to the machine and the floor and checked both , they should never walk unless they are unlevel
Dec 30, 2009 | Washing Machines
Washer spins out of balance, Heavy or lite loads. Washer also walks around. Mostly on final spin.
There is a tub damper under the top of the washer which is probably out of place or damaged. It is a v-shaped rod with a cup on the end.
Charlie
Aug 14, 2009 | Amana ALW480DA Top Load Washer
Frigidaire Gallery Series Frontloader no final spin
I had the same problem. Here's a link that might help:
http://applianceguru.com/forum2/2937.html
I removed the hoses and pump and found the filter in the hose leading from the washer was clogged with a shoelace, $2.35 in loose change and a few GI Joe issued M4's. :-) Once I pulled that filter out and cleaned the **** the washer runs like a champ.
Apr 30, 2009 | Washing Machines
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTR1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
