Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi image rolls horizontally almost as soon as tv is turn on. It gets ok after tv is on for a while, (and I mean for a while!). model is mitsubishi vs-45605. we bought it on 1999. is it worth it to repair? Thank you soooo much for your help
    Sergeant:
  • 233 Answers
This is a case of bad capacitors in the PIP (picture in picture) module. If you have any electronics repair experience, you should be able to do the repair yourself. Here is some more detailed instructions:
http://forum.eserviceinfo.com/viewtopic.php?p=59404#59404
Posted on Jan 15, 2009
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Rolling horizontal lines on 62" Mitsubishi
That problem is caused by failed Capacitors on the signal and FMT power boards. which is a very common problem for mitsubishi TVs. There are repair kits available for the V26 dlp which contain the capacitors and instructions on how to do the repair. Heres a link check under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi vs-7071 rear projection tv
hey i have had the same prob on my other tv .it was about 300 to get it fixed.if you havent allready fixed it and if your not to fare away,id like to buy the screen
Jul 29, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi model WT-A42
maybe theres aproblem between the power supply and in the horizontal circuit of your tv
Jul 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-50707
Click here to get more info on the subject and also check the other links in that post.
Good Luck.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Continuous rolling screen.
check out ctechnicians.com and find the error code
Dec 24, 2007 | Mitsubishi VS-60607 TV
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
194 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
