My cursor darts to a corner without moving mouse
As I type my cursor flips out and moves to a corner or it will move to another place in what I've typed without touching the mouse pad. It happens quite a bit.
I thought it was just my laptop, but my daughter has the same laptop and hers does it too.
HP Pavillion Entertainment PC dv6227cl with vista
  • Anonymous Feb 20, 2009
    siht ekil gnipyt ni stluser hcihw tfel eht ot sveom ti
  • 514 Answers
Do you have Word with that weird little paperclip helper? some computers have presets that make it (or your cursor) move out of the way so you can see what you're typing as that many people (not including me!) touch type while looking at the screen and the cursor being in the way is VERY distracting to them.
Posted on Jan 15, 2009
Mousepad on laptop too sensitive, jumps and opens links all the time
Hi I also have OS Vista, try this:-
go to the bottom left corner of the screen to the windows button and single click it, move the cursor to "control panel", leave it there and a whole new list of stuff will appear, move the cursor to "personalization" and click it once. This will open a box on the screen. Single click on "mouse pointers", this will open another smaller box with 8 tabs inside. You can click on any of these tabs and adjust your mouse actions to your own preferences, eg; how the pointer looks, how fast you double click, how fast the pointer moves on the screen, anything you like :)
Once you have made all your adjustments, click "apply" in the bottom right corner of the box and this will save the changes you've made.
I hope this helps.
May 06, 2012 | Medion Computers & Internet
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
The cursor jumps backward often while I type, and writes behind where I am, lines behind.
You're probably hitting the touchpad with the heel of your hand while typing. Many people do it without realizing it, and the computer is just moving the cursor to where it thinks you're telling it to go. If you're doing lots of typing, you may want to plug in a USB external mouse and turn off the touchpad. This eliminates the cursor jumping, and a regular mouse makes moving around a document and selecting text easier.
Sep 14, 2011 | Dell Inspiron 6400 Notebook
My cursor gets stuck up & when i want to move it to another place i ve to minimize file click outside the that window & maximize file & then i moves
Remove the ball by turning the cover counter clockwice and clean the rollers inside.
Or better buy an optical mouse.
Hope this will help you.
Mar 13, 2011 | Dell U0636 Mouse
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Cursor won't stay where I move it with the mouse
Hi, your first problem (and possibly second problem) sounds like it's the "Insert" function on your keyboard. I've seen this a lot. Find the Insert key on your keyboard. It's normally off to the right side with the Home, End, Page Up, and Page Down keys. When you have the problem, press the Insert key and then keep typing. It should toggle between the cursor moving with typing, and not. If this was helpful, please rate my response. Thanks!
May 15, 2009 | Dell Latitude D820 Notebook
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
The cursor moves by itself during typing. It jumps to a position and I find myself typing in the wrong place.
I have found this is usually the small button in the middle of the keyboard (mouse button) I have tried some software to remove this problem but it did not on my laptop I ended up carefully removing the key board and disconnecting the two wires that go to the button My cursors kept moving across the screen
Feb 18, 2009 | Acer Aspire 5720-6661 Notebook PC
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Computers & Internet Logo
470 people viewed this question
David Payne
David Payne
