Question about Toshiba Satellite 1135-S155 Notebook
My cd/dvd rom will spin briefly but will not read a disk and the diagnostics show that there is no drive installed?
    President:
  • 2,692 Answers
Heads either dirty or out of alignment. They make cleaner kits . Thy that first. If that does nto work, replace CD / DVD player /burner
Posted on Jan 15, 2009
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
Mar 05, 2014 | OEM Systems Dell Xps 15 L502x L501x Blu...
My notebook suddenly shut down itself, then after i restart, it show select which drive to boot (but no option to let me select). Then i try to reformat it, but it show no harddisk install? i have try...
This means that no "bootable" CD-ROM was loaded into the CD-drive, *AND* that the "bootable" files could *NOT* be read from the disk-drive.
> it show no hard-disk install
Well, it shows that either:
* no electrical power is reaching the disk-drive
* the electronics "underneath" the spinning-part of the disk-drive have failed
* the "spinning" part of the disk-drive is not spinning (dead motor?)
* the disk is spinning, but nothing can be read from the disk-drive.
Try connecting the disk-drive to another computer.
If it is detected, that's good.
If not, then your disk-drive has a BIG problem,
and replacing it (with or without exercising any "warranty'") is your only way to move forward.
Sep 30, 2010 | ASUS A3Ac Notebook
When inserting a disk, the CD ROM spins but does not read the disk nor does it show up in "My Computer". Under Device Manager, it shows up with an exclamation mark. I've uninstalled and re-installed it to...
Please try running the Microsoft Fix It from the link below. It should resolve the issue for you.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Robert from Blitware
Jul 08, 2010 | Dell Inspiron 5100 System Board (...
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
I have lenovo y410 laptop with windows vista installed on it.i changed the os to windows xp ,everything is working fine but the MATSHITE DVD RAM UJ85js is not reading the content of the cd ,but this drive...
Can the "bad" CD-R be properly read on some other computer?
If not, then the disk itself is the problem.
Otherwise, changing from Vista to XP does _NOT_ produce the type of problems that you are reporting.
Mar 22, 2010 | Sony 8x Internal Blu-ray...
Latitude C840 wont reconize optical drive in BIOS
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the the whole drive unit.
Apr 25, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
CD/DVD Rom suddenly not reading DVDs. I had iTunes installed and had deleted these files. Any connection and how do I fix my DVD player BA
DVDs demand a much higher precision to read a disk than do CDs and when they go down the tubes, the DVD is the first place it will show up. You can try using a cleaning disk but this is often not successful.
Mar 06, 2009 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Dell D600 not reading any type of disk
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Jan 14, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Toshiba Satellite 1135-S155 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
