Question about Indesit WA 125 Front Load Washer
Indesit widl126s The above named waher dryer (Indesit WIDL126S) is not spinning. There is 1 red & 2 green flashing lights on the machine which starts flashing.any one knows what's wrong.
  • 3 more comments
  • Anonymous Jan 19, 2008
    I have a WIDL102 washer dryer and the same is happening, if I put it on any cycle then it will stay on the 1st stage for up to 2 hours. I can drain it using the control dial manually but if i set it to spin the the red door lock button flashes very fast and 2 green function leds flash as well. I have tried Indisits very useful advise of unplugging and plugging back in again (just turn it off on on agin) but it is still a problem!! Any suggestions??
  • huggisheed Apr 24, 2008
    My Problem Is . My machine takes water in then stops goes no further . I can drain the water if i turn the dial to drain . It wont spin on a spin programe so im guessing its something to do with the spin . I have check every pipe/drain within the machine every is clear . iv cleaned all the filters ect. The machine is only over a year old so didnt think it would be the brushes but could i be wrong . im quite techincal mindy so to my understanding if you give the rotor of the motor a spin without load eg taking the belt off . i did this and nothing . Just wandering if anybody had same problem or someone might have a soultion . my fingers pointing at the controller but again i could be wrong . comments and help would be apprectied . No rush bought a new Zanussi Since then lol . crappy indesit .
  • Daniel
    Daniel Nov 25, 2013
    use a hair dryer to warm the engin and all the parts from bottom of the machine, worked for me. bad news - it is just temporary, when you need to use it again you need to dry it again :)
  • Anonymous Mar 21, 2014
    indesit wil113 bouncing bad and green and red light flashing
  • Anonymous Mar 25, 2014
    There is smoke coming from the back when set to washing cycle.the lights keep flicking on and off
  • 1,294 Answers
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Posted on Jun 16, 2007
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Does not drain
is it not blocked at the sump as some time this happens as it got a little door on the front if so it could be blocked hear
Dec 07, 2009 | Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
All the red & green led's are flashing very dull
The problem is in the power supply circuit of controller PCB. Replace C9 (680uF/10V) with a new one.
Mar 21, 2009 | Washing Machines
Indesit widl126s humming noise on spin cycle and doesnt drain
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Mar 06, 2009 | Indesit WA 125 Front Load Washer
Ido not have a manual for this machine (WIDL126 ) and don't know
Nov 20, 2008 | Indesit Washing Machines
I've got an Indesit WIDL126S and it is leaking. The water escapes from behind a brass plate with wires on. The brass plate is held on by a 10mm nut. Do I need to buy a bearing and seal kit?
this sounds like the heater you are looking at. try tightening the 10mm nut a bit. if that doesn't work. loosen the nut, pull heater out and use some sealant. why do you think you need to replace bearings and seals?
Aug 23, 2008 | Indesit Washing Machines
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Indesit WA 125 Front Load Washer Logo
1,468 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
