Question about RCA HD61LPW42 61" Rear Projection HDTV
Black lines going across the screen.
Looks magnified and larger than normal with the black lines. Kind of off centered.?
  • daniellebazi Jan 17, 2009
    It was not the tv but thankyou it is resolved.
    New Friend:
  • 111 Answers
POWER SMOOTHING CAPACITORS ARE FAULTY.
CAN YOU CHECK THE CIRCUIT.
OR IT CAN BE OCCURE BECAUSE OF SIGNAL OVERLOADING ,(BAD RF STAGE)
OR BAD VERTICAL AMP.
NUWAN.
Posted on Jan 15, 2009
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
I have a Sony lcd data projector- VPL-SC50.. There is a big black blob in the middle, with other lines near the edges. And the blob is growing larger now. But it does not look like a burn out, it looks...
Normally a "blob" on an LCD is a delamination of one or more of the LCD panels. But, they are usually not black. You may have a poor ribbon cable connection from the main board to the LCD panels....there is a ribbon connection to each of the Red, Green and Blue panels. It's either that or a main board failure, but certainly soemthing you want the factory or other authorized service center to check out.
Good luck.
Aug 12, 2010 | Sony VPL SC50 projector lamp Projector...
Pt61g42v.this is a panasonic 61 FOCUS OUT
my tv flat lined the screen went black with a twisted line across the screen what is the problem?
May 13, 2010 | Televison & Video
Black Line bottom of LCD Monitor
May be a manufacture defect or the Screen goes wiped out during transportation.
Call to the support for warranty issues immediately.
Regards
Ellin
Sep 26, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Thin line across computer screen
This might be a mediaplayer issue. Google on EHtray.exe and you will find a microsoft page with a number of filenames related to these kind of problems. Check by pressing CNRL-ALT-DEL and check if you see any of the filenames on the processes tab. Than stop the file and see if the black line disappears.
Jul 05, 2008 | HP w17e Monitor
Split screen
interference in the wallsocket, try plug the unit in separate outlet! if nothing happen you're dvd have leak capacitor on the power supply board to filter the interference!
Jan 29, 2008 | RCA DRC8052N DVD Recorder
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
RCA HD61LPW42 61" Rear Projection HDTV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
