JVC HR-XVC33U DVD Player/VCR Logo
Jan Wheat Posted on Jun 15, 2007
JVC HR-XV33U DVD/VCR
My dad's DVD player shows a split screen or wavy black/white/gray lines when a DVD is inserted. Tried 3 different DVDS, 2 home recorded and 1 profesionally recorded and got same thing. Any suggestions? No problems on the VCR side.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 08, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
249
Points
5
Press and hold the Progressive Scan button for more than 3 seconds. It should clear right up.
Anonymous
Level 1:
Scholar:
  • Contributor 47 Answers
  • Posted on Jun 16, 2007
Anonymous
Contributor
Level 1:
Scholar:
Answers
47
Questions
0
Helped
17075
Points
77
The problem probably lies in the analog to digital converter. This is a hardware IC problem usually only repairable by changing the board. In most cases, this is cost prohibitive. My suggestion is to check the back of the unit and see if it has external video in jacks. Or auxillary in , if it does buy a cheap DVD player from one of the big box stores. Also if you do this buy the replacement warranty, it usually only costs $10 or less. Scrivitron
DVD region hack available?
If you suffer from region code troubles, you can download a region free DVD player software tool on your pc and then you can play discs of any regions you want. You can try Leawo Blu-ray Player which is a free Blu-ray player and a region free player.
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
1helpful
Dvd side used to work but now when i put in a dvd it says NO DISC. I've tried several different dvds but still says the same thing. I have the HR-XVC25U
Hi
This is really strange. This summer my DVD side of my JVC Combo did the same thing. I went through the circuitry with a scope but I couldn't nail it down to one component. I called JVC about a new board but they wanted more than a new unit costs. They wouldn't tell me if this is a problem across the whole line. I ended up buying a new Panasonic combo at WalMart for less than $100. Its working well for now.
Thanks
Repeat recording 5x week for same show
Found the solution in the on-line manual, around p. 33. Thanks.
DVD is stuck in my JVC VCR/DVD Combo
Find the small hole on the front of the player. Get a small paper clip and straighten it out. Insert one end into the hole and the DVD should pop out.
2answers
Seinfeld DVD episodes won't play
It is probably not your VCR. If it is only the Seinfeld DVD's then the format that the production company wrote on those few episodes are incompatible with your vcr. I know I'm not solving your problem much, but don't go waste money on a brand new Vcr when not needed.
Split Screen Output
check on the remote if got some function of format ntsc or pal or check on the menu of the dvd
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
Video input from dvd player shows as black screen w/ squigly color lines
have you tried other devices for input...vcr, or other dvd players to see if it is a problem with the player or with the tv? Check the output setting for the dvd player (1080i etc) and ensure you are connecting to the proper inputs for either analog or digital signals (RCA inputs or RGB).
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
