My mp3 plays a song for a few seconds and then a loud beep sound (steady) comes on...I can't turn it off or do anything to stop that sound...it freezes and i have to take the battery out to make it stop..........what's wrong with this thing????????
That happened to me, and changing the battery solved the problem... until the player died altogether about one month later. I haven't yet found a solution to THAT particular issue...
Back in the days there use to be a feature in cd player that allowed the user to preview the first few seconds of a track- sounds like your mp3 player has this feature- you need to look at the manual to turn it off- or provide a model number so we can help you locate a manual .
good luck https://www.6ya.com/mrmmike
MP3 songs are recorded at different levels. Many modern tunes have been deliberately recorded loud by the record companies for maximum effect.
If you are recording the songs yourself some recording software has a "normalize" feature. This increases or reduces the volume of the track to a certain level. Especially useful when you have tracks at different levels. By the way this is how they get CD tracks to play at the same levels. So you don't have to turn up the volume or turn it down every time a new track plays.
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Your Uncle's player is stuck in INTRO mode. To remedy this problem
1. Play a song
2. press the button on the side of the player
3. Select PLAY MODE
4. Choose NORMAL
Do you mean it plays a few seconds then skips onto the next song? If that is the case then most likely you have "Intro" play set which only plays a few seconds as a introduction then skips to the next time.
To fix this, during music playback, press the [menu] button, then there should be an option there to change it from "Intro" to "NORMAL" instead.
Yes. You have to have an active account to keep listening to those songs. On another note (no pun intended) anything that you OWN in your music files will play for you.
I quit the subscription from Best Buy, deleted the songs I didn't own and now I am satisfied.
Though I do not have a ipod shuffle, it sounds like you set it to run on "sample" which is a setting to play only a few seconds of the song then stop, are you using any other program besides itunes?
If you installed the firmware update, you might have forgotten to change the device to MSC mode.. try going to settings>USB mode>MSC
This should probably work..
to stop a song while its playing, click the |<< button while you have the screen with the current song. (you can pause a song on this same screen with the >|| button) If you have gone back to any of the menu screens, wait for a couple seconds and the player will automatically go back tot he song display screen so you can stop the song.
