Question about Panasonic Televison & Video
Burned resistors r319,r320
Does anyone know the value and tolerance of these resistors.when i received this dvd player the resistors were ok,but no power from main power board.
    New Friend:
  • 70 Answers
hi mate, i might be able to help you but i need to know the exact model number and brand of your dvd player.kindly email it to
Posted on Jan 15, 2009
Values of the resistors
Resistors R1, R2, R3, and R4 are arranged in a circuit as shown in the figure above. The direction of positive currents I1, I2, I3, and I4 through the resistors are shown. (i.e., negative current values correspond to currents in the opposite direction to that shown above). The values for the resistors and the batteries in the circuit are: R1 = 100 ?, R2 = 200 ?, R3 = 30 ?, R4 = 400 ?, V1 = 4 V, and V2 = 12 V.
Nov 06, 2016 | Televison & Video
Motor Joy
Hey boss. Just follow this guide and replace with a resistor that matches the value and tolerance. You have a 5 Band resistor, follow the guild and you should be good. Click here for a chart to help you identify the values.
Jul 06, 2013 | Car Audio & Video
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
My samsung dvd ht-z210 has a problem.when i press the ON key it only say protect. how will i solve this? pls help..
hi, I'm Renzo from Italy. I have your same problem, so I've opened my equipment and I've found a resistor burned. The problem now that I don't the value of the resistor. if you have the same problem and find the value of the resistor, please send me an email to
Jul 13, 2009 | Philips Magnavox DVD/VCR Dual Player
R2728 and R2734 Resistor values and part#'s
perhaps a Zenith repair shop would be able to assist .
Jan 28, 2018 | Zenith R45W46 45" Rear Projection...
those are 6.8 ohm 1watt metal film resistors 5% tolerance
Jul 22, 2008 | Philips 43PP9202 43" Rear Projection...
Excessive brightness with retrace lines
Here are the values:
RY04 >>>> 68 ohms >>>> 1 Watt
RY04A >>> 47 ohms >>>> 0.5 watt
RY02A >>> 330 Ohms >>> 0.25 Watt.
All resistors should be 5% tolerance.
Apr 17, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Televison & Video Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
