Question about Samsung HL-P5063W 50" Rear Projection HDTV
No Picture or sound
The lamp light and the stand by light is on .I just changed out the lamp and the cooling fan. Is the ballast not working? What is the part number of the ballast to order? thanks
  • tonnyaa Feb 09, 2009
    all the lights on the front of tv flash red
  • zsports04 Feb 20, 2009
    changed the color wheel, Lamp and ballast still no picture or sound, anyone have an answer?
Ballast number is BP96-00690A
Posted on Feb 20, 2009
Model WD-65734. Why is there no picture?
Never heard of a color wheel needing to be replaced. Both cooling fans need to be clean and turn easily. Color wheel fan needs to turn easily. If any one of these motors does not turn, the controller will cause a shut-down. The Xenon lamp uses high voltage to operate. If the power supply was damaged, the lamp won't light. The sparking on the ballast board indicates that dirt or dust may be causing the problem. Also, the clamping diodes and regulator may be defective. If possible, try replacing the lamp power board. Regards.
Dec 22, 2015 | Mitsubishi WD Televison & Video
Hi i have a kdf e50 a12u the bulb went so i relaced it and still no picture just keeps flashing green and red any ideas?
Ballast board it is what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
You need to make sure you do not have any defective Cooling Fans -If Lamp Fan is Defective Lamp will not come on either.But if Fan is running and Lamp Fails to light Ballast board
Sep 30, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Another Bad Ballast?
Go to this website and type in your model number see what they list in parts /prices They might have free service Manual you can print out online.
1-800-638-3328 wait untill you get ballast board ,before making any desision about more parts
If it turns out that ballast didnt clear problem then return it to company.Have you Checked Lamp Fan, Ballast Fan,some DLPs will have up to 4 Fans, if fans stops cooling set will shut off
Apr 20, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Jun 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung HLN5065W turns itself off after about 15 minutes, and all three lights on the front panel flash. The first couple of times this happened, there was a loud muffled sound before it shut itself...
This is a DLP projection that has a ballast and color wheel along with a lamp. The three flashing lights on the front are a diagnostic code. The exact meaning is listed in the owner's manual under troubleshooting. I don't have the manual for your model with me at the moment, so I can't look it up. Since the unit works OK for a while, it suggests that a component is failing under heat stress. This is often the ballast. The ballast is the part that provides the power for the lamp similar to the ballast in a flourescent light. Check the manual for the code and post it here. Also, because your model uses 2 different ballast/lamp combinations, you will need to get the lamp number off of the lamp. Please post that here too.
In the meantime, check the rear area for any obstruction in the air flow. There should be a fan in the rear that needs to be clear of debris and can turn freely. With the set unplugged, try turning hte fan by hand. It should turn easily and continue on its own slowing down to a stop. If it stops suddenly, the fan may be defective and not moving enough air to keep the lamp cool.
Keep us posted.
Dan
Apr 25, 2009 | Samsung HLN5065W 50" Rear Projection...
Turns itself off after 5 seconds of run time. will not stay on, cooling fans work, lights up screen and shows picture, then shuts off. light flash on front right corner.
Either lamp is failing (not covered under any warranty), or the ballast has failed. Or it may be a problem with the power supply, or even the fans... What is the picture next to the flashing light? If it's only the lamp light, then either lamp or ballast, if temp is flashing (the thermometer), it will be fans, temperature sensors, main board or power supply.
Apr 22, 2009 | Samsung HL-T5675S Television
55 in loewe articos rear projection
You might have defective Fan if Fan stops running Lamp will not Light also keep in mind Ballast board it what turns lamp on and Fan is what keeps Lamp cool, and most of the time if set is not comming on Lamp is Bad. Call Encompass Parts 1-800-638-3228 or UED 1-800-648-6657 main 3 parts to DLP is Lamp,Ballast board ,Lamp Fan.Id say you have Bad Lamp! God Bless and hve a wonderfull Day.
Nov 02, 2008 | Loewe Articos 55 55" Rear Projection...
No picture
If the red light stays steady, and the green light blinks 9 times then repeats, it is most likely the lamp #23311083A about $200. Otherwise, if a cooling fan is not working, it could possibly cause a shutdown problem. You can't always tell a bulb is bad by looking at it. Another possibility is the lamp ballast, but I would try a new bulb first.
Feb 10, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
No Picture No Sound
Check the lamp first ,it could have blown.If the lamp looks good consider the following,The power supply gives the ballast the voltage it needs to strike the lamp,its hard to tell without doing some voltage measurements,you can not measure the output of the ballast but the voltage from the power supply to the ballast yes. Call professional help if you are not familiar with safety when servicing tv's.
Sep 22, 2006 | Panasonic PT-40LC12 40" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
169 people viewed this question
Jerry Greenberg
Jerry Greenberg
