Question about Nokia N95 Cellular Phone
Nokia N95-2 Camera light stays on. Even when turned off
I have tried updating firmwear and disconnecting the battery for 10hrs (+ pressing on/off switch)
no luck,
every one seems to have this problem but no solutions on nokia.com or other sources
    Scholar:
  • 61 Answers
The power regulator between the power source and your camera seems to have the problem. it's not enough to just consult online. someone has to do not only the technical advises but the hands-on work as well. bring it to an accredited service center as they too had the reliable device parts that might replace the defects as well.
Posted on Jan 15, 2009
My phone got switched off while updating softwares. now it is not getting started what to do
My Nokia 6303 does not proceed forward from Nokia Title after switching on, rather it hangs after Nokia title and gives lights from its buttons but no button even switch on/off works until i remove my battery and insert again and then switch on but still same problem persist.kindly guide if you can
Jul 21, 2010 | Nokia 6303 Cell Phone
Hi- the flash light came on my E71, and remains on, even after phone restart, and disconnection of the battery. How can I turn off this light. thanks
Go to your camera settings and you should see a FLASH LIGHT option -
if not click or choose option and you should see the option to turn the flash off on there.
see if that helps -
thanks
Mar 30, 2010 | Nokia E71 Smartphone
Same problem
now flash with hwk dongle OR JAF box
Aug 18, 2009 | Nokia N73 Cellular Phone
Nokia 6300 wont turn on, blue lights on side stay on
I had a simliar problem with my k800i, it turned out that it needed its firmware/software updated. So u can either get it "flashed" at a shop (around £10) or you can try doing it at home but you'll need the software and the data cable for the phone. Google it i'm sure you'll find something. Good luck
Sep 27, 2008 | Nokia 6300 Cellular Phone
HELP ! Frozen Nokia N95
try to push and hold together buttons * ,3 and green handset then press power ( still holding buttons) .
If it's not work you must do a manual software upgrade in service centre or someone who have special hardware for that. if you need that you can contact me at pluciorx@wp.eu
Sep 13, 2008 | Nokia N95 Cellular Phone
Stuck on nokia start up screen
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Tip! Only use one Anti Virus Application on your phone.
If the above doesn't work try another update. (it may have mis-updated).
Before updating software you should check that there's a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Mar 25, 2008 | Nokia N70 Cellular Phone
Formatting N95 Nokia Phone
WARNING
You could try this, but don't hold much hope:
Yes! I know, you need someone to press the ON button.
Or try:
Hard reset code *#7780#
Mar 02, 2008 | Nokia N73 Cellular Phone
Can't turn on the phone
I'm seeing two scenarios with possibly a third: 1. You turn it off and it doesn't turn on immediately. 2. You turn it off and it takes an usually long time to turn on. With the 1st one: it's normal for the SE phones to not turn on immediately after its been turned off. The second sceranio could be firmwear related, in that a firmwear update could solve that problem. The third, possible, scenario is that it no longer turns on at all, in that it could be completely dead unless you see flashing LED lights in the infra red port, if you do see flashing LED lights. It can be saved
Sep 23, 2007 | Sony Ericsson K800i Cellular Phone
Nokia 6600 does not open
aapko apne cellular phone ka software update karna hoga
Sep 18, 2007 | Nokia 6600
Nokia N73 software update problem
during software update N73, the phone does not switch on. what can i do
Aug 07, 2007 | Nokia N73 Cellular Phone
Nokia N95 Cellular Phone Logo
157 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
