Question about HP Compaq d530 PC Desktop
I have a HP lcd projector. It works fine when connected to dvd player but when connected to PC it does not. The picture and other icons are ghosted! is the problem with pc or projector?
    President:
  • 2,692 Answers
PC either driver missing or wrong one.
GO to the HP website with you model number and the version of windows that you are running and download and install the driver for your icd projector device for your computer . It must match the version of windows that you have. If one is not availavle then you cvannot use the device with the computer untill one is written.
http://welcome.hp.com/country/us/en/support.html
Posted on Jan 15, 2009
Is there anyway that i can connect a nec vt695 to my tv
Hello.
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
Sep 19, 2010 | NEC VT695 LCD Projector
Ghosting Image
hi!!!
may be the lens has alignment the lens
of your projector there a adjustment
try to adjust!!!
Sep 21, 2008 | Philips ProScreen 4750 Impact Multimedia...
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
DVD connection
You can use any dvd player to connect to this unit as long as it has either a S-Video plug or uses RCA plugs. These cables only transmit the Picture and not the sound. You will need to connect the DVD player up to something that can produce the sound as the HP only has a mono speaker.
May 21, 2009 | HP MP3220 Multimedia Projector
YPbPr and YCbCr signal
with component, if there is not a solid signal, it'll go blue. if the dvd is dirty, the player is dirty, or any other break in signal, it'll go blue. clean your dvd and/or player.
Feb 26, 2009 | LG RD-JT30 Multimedia Projector
Projector giving green picture it is ok with RCA inputs ok with S video input but if i connect component connector like 15 pin vga from dvd player it gives green picture but with same cable if i connect pc...
I think, the issue might be because of lenght of the composite cable. Not all projectors can "recognize the signal" on too long composite cables, try a "standard size" cable used on monitors, it is i THINK 1,8 feet long...? Dunno. Try two short cables and see if you get "green" - if not, then your cable is too long and gives the signal to much "resistance", so your projector can "read" only one of the color channels, in your case green. If your projector setup requires long cables (and it usually does ;) ), you will have to stick to Cinch connectors and analog video signal, which I have tested on 35m long cable without any visible quality loss. Hope this helps. ;)
Feb 20, 2009 | HP Compaq nx7010 Notebook
Pc connected vp6121 DLP projector shows only blue images
THE DRIVER FOR THE PROJECT OR THE INSTALLATIONAL SOFTWARE MAYBE USEFUL
Feb 12, 2009 | HP Digital Projector Vp6110 Multimedia...
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
Media player movie picture won't display
Yes, I have the same problem with a Dell Inspiron 700m laptop. I have never been able to show videos using two seemingly compatible devices. This is not a projector issue however, as my projector displays video DVD fine from this PC, only videos inserted into PowerPoint will not play. Using another computer it works fine. Imagine that, Dell selling two highly practical devices that are not compatible.
Nov 10, 2006 | Dell 2300MP Multimedia Projector
HP Compaq d530 PC Desktop Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
