Images and letters are fuzzy on my Westinghouse Monitor
Westinghouse LCM-22w3 monitor
I have the resolution set at the recommended settings in the owners manual. It is fine when I first turn on computer, as the day goes on it start to lose sharpness with shadows and fuzziness around letters when working in Word or on the Internet, really anything with text. If I hit reset on the monitor menu and then auto adjust a few times it clears up temporarily, returns with an hour or two. Sometimes quicker. Called their tech support - no help whatsoever.
HELP!! Driving me crazy as I am a medical transcriptionist and this monitor is what I look at all day long!
  • Anonymous Mar 30, 2009
    I had the same problem. Fiddled with the monitor cable and now it`s fine.
Wow! Read the "bad monitor cable"got up, went around behind the monitor, tightened the thumbs screws on oth ends (didn't feel real loose), moved the cable around, came back around and it's back to normal! Clear as a bell!
Posted on Nov 19, 2009
  • 30 Answers
Your monitor settings are not correct or you have a bad monitor cable. Wide screen settings are sometimes hard to figure when you have a wide screen Westinghouse mntr. You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest?You have tried all common resolutions? 1024 x 768, 1280 x 800, 1280 x 720? I assume your video drivers are the latest? That monitor is a **** btw! take it back to Best Buy. No other store sells them that I know of.
Posted on Jan 15, 2009
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
Can a westinghouse lcm-22w3 be used as a tv
Yes, you will just need to have the right output on your cable box with some conversion. (eg. if you have RGB out of the back of the box you will have to get a break out cable that goes from that to VGA for the back of your monitor.
Apr 28, 2014 | Westinghouse Electric LCM-22W3 22 inch LCD...
My westinghouse LCD LCM22w3 is not turning on. The switch light will turn on for a few seconds but then turns off. I have no imput signal
Helo,
This is a very common problem with the LCM-22W3 monitors. The problem is caused by a failure of the filter capacitors in the power supply board. Here is a link to a repair guide that shows how to open the unit and what to look for and replace to repair the monitor. This is a very easy repair.
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-22w3/
Jan 26, 2013 | Westinghouse Computers & Internet
Not turning on
Check the capacitors on the power supply board in the unit. This is a very common problem with this unit but it is easy to repair. Here is a link to a repair guide that shows how to open the monitor and what to look for.
I hope this helps.
May 20, 2012 | Westinghouse Electric LCM-22W3 22 inch LCD...
My Westinghouse LCM 22w3 was working great with full res at 19xx x 16xx. Now it is no longer recognized by my Windows Vista system. In Device manager, the monitor shows as a General PnP 17" with res...
I suggest you test your computer by using a different known good monitor. If it works ok you will know your Westinghouse has a fault and if it doesn't you will know there is a problem with your computer (video card maybe?)..
Sep 29, 2017 | Westinghouse Electric LCM-22W3 22 inch LCD...
Westinghouse LCM 22W3 22" has electric service, but no response
I did not fix the problem, but found out it probably is a power supply which is a very common problem with this design of this make of monitor. I think I need to get to get it fixed by a professional.
thank you Ann Moctezuma
Nov 19, 2009 | Westinghouse Computers & Internet
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
My monitor will shut itself off randomly
The power supply on this model has a know issue. We just posted the repair guide on our web site at: www.ccl-la.com It gives a step by step repair guide for the Westinghouse LCM-22W3 monitor. If you don't want to do the repair yourself do do offer a repair service for $35 plus return shipping. If youhave any questions just let us know through our web site.
I hope this helps,If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 06, 2009 | Westinghouse LCM-22w2 Television
Dismantling of a Westinghouse LCM-22w3
Make sure that all three screws are removed from the back of the display. This is in addition to the four that hold the stand on.
Feb 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Computers & Internet Logo
1,384 people viewed this question
David Payne
David Payne
