Question about 3G Technology GM-171B 17" Flat Panel LCD Monitor
I just unhooked the monitor to move it and must have reset the coloration somehow. Now it is way too green and I'm not sure how to simply reset it to the way it was.
After fiddling with the buttons for a bit, I found the factory reset. Thanks though.
Posted on Jan 15, 2009
I have an AOC 712swa-1 monitor. All of the sudden I have no color and it looks like an eerie green hue. I hit the buttons on the front of the monitor, but I can't get them to work! I want to go to...
In all probability, you've simply got a loose connector. Disconnect it from the computer and the power. Disconnect the video and power wire from the unit. Make sure they're clean. Connect everything back up. If that doesn't do it, we'll try something else.
Jun 16, 2011 | AOC Computers & Internet
Loss of one color in monitor
some of the vga conncetror pin is not working then that type of problem is presnet my sugestion is change the vga cable and install new one .....ok
Sep 22, 2009 | Computers & Internet
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
My lg monitor has turned green how to fix it
A common cause of a green screen is simply that the cable is not securely connected to the video card. Try to unplug the monitor cable from the back of the computer, and then plug it back in again and securing it with the thumb screws if possible. If that does not work, there may be a reset option in the monitor's configuration menu.
What make and model is your monitor?
Is it a solid green color? Does it change after a period of time being left on?
Mar 08, 2009 | LG Studioworks 700S 17" CRT Monitor
Dell E177FP monitor won't turn off in power saving mode
I had the same problem and I went to the first button on the monitor to the left(main menu) then with the button to the right (-) I scrolled down to factory reset. I also did the osd setting and I'm not sure what fixed it, but I havn't had the problem sence.
Jan 05, 2009 | Dell E177FP LCD Monitor
Help.. LCD colors
Reconnect your cables!  Somehow you don't have red and green in there, just shades of blue, right?  And it doesn't depend on whether you're running a browser or something else?
Make sure everything's tight and if you can (but only if tightening cables didn't work,) check that your computer's putting out a normal signal by testing another monitor with that computer.
Nov 11, 2007 | ViewSonic VA520 15" Flat Panel LCD Monitor
3G Technology GM-171B 17" Flat Panel LCD Monitor Logo
66 people viewed this question
Top 3G Technology Computers & Internet Experts
William Miller
William Miller
Chris Larocque
Daniel Quinn
Daniel Quinn
Are you a 3G Technology Computer and Internet Expert? Answer questions, earn points and help others
