Question about Toshiba Satellite L10 Notebook
I have a dell XPS M1210 it is about 3 years old. It has Vista. I downloaded the latest Vista updates today and now my mouse pad is stuck. The arrow is in the middle of the screen pointing slightly to the left. I have tried shutting down four times with no change. The message on the screen says "An ActiveX control on this page might be unsafe to interact with other parts of the page. Do you want to allow this interaction?" I can't click no because the mouse won't move. I also tried Control/alt/deleat to get to the task manager. Once again I can't do anything because the mouse won't move.
    President:
  • 2,559 Answers
You can use the Tab key,the Alt key,and the control key to navigate.(use one key at at time,Not a combination of keys)Then go to add remove programs and remove the touch pad software.then restart
Posted on Jan 15, 2009
    Problem Solver:
  • 9 Answers
Try shutting it off, remove the power cord AND the battery...let it set for about 5 minutes, put the battery in, turn it on ...see if that clears the issue.
Dell Vostro with XP - cursor is running rogue and endlessly going backward.
This "can" be malware, but is most likely your pointer device going wonky. First unplug the mouse, trackball, or whatever it is you are using for a mouse. If you are still using an old PS2 connection (round plug), consider getting a USB mouse to replace it.
Plug your mouse back in and see if it solves the problem.
Try a new mouse.
If it's not the mouse (you just said the cursor is moving) it could be that the left arrow on your keyboard is stuck. In that case, rake your keyboard, tap ******* the arrow keys, turn over the keyboard and shake out any large Cheeto crumbs, use compressed air (if possible) to blow the dust out.
Unplug your keyboard from the computer and plug it back in. If you are still using the old PS2 keyboard (round plug), consider getting a USB keyboard to replace it. *** warning
*** warning, do NOT throw out the old PS2 plug keyboard if you replace it. You may need it to get into the BIOS some time in the future if the electronics don't recognize a USB keyboard on boot.
Feb 07, 2018 | Dell Vostro 1520 Notebook
Dell XPS M1530 Vista originally installed - Fresh installed Win7 and now touch pad does not work - the right button works, and sometimes the left, but the touch pad does not. I've install the latest...
If you've reinstalled the drivers for the touchpad, the issue is likely the hardware- if in warranty, contact Dell tech support- if not, you may need to purchase the palmrest assembly and consult support.dell.com for the install instructions
Oct 24, 2010 | Dell Inspiron 1545 Notebook
Dell XPS M 1530 does not detect the CD Drive . It attempts to format the same while CD is inserted . The OS was Vista and was upgraded to Win 7 . Now I want to Downgrade to Win XP and make it functional ....
Go to device manager> dvd drive and properties check the dvd drive details and download the corrsponding firm ware HERE
then update to the latest Bios HERE
Dont forget to say thanks!
Aug 10, 2010 | Dell XPS M1530 Laptop
Screen is black after sleep/hib, Dell studio XPS, Vista.
Hibernate problems are generally associated with the Video Driver. Suggestions:
  1. Update the BIOS to the current release. Here is the latest for the 1645. http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=STUDIOXPS1645&os=WV64&osl=en&catid=&impid=
  2. Update the video driver.
Dec 19, 2009 | Dell Studio XPS 16 Notebook
Hi i have Dell XPS laptop...USB mouse not working
Make sure you have the correct driver downloaded.
Dec 18, 2009 | Dell U0636 Mouse
Philips PA1039 Wireless mouse and Dell XPS laptop
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | Philips PA1039 Mouse
Dell touchpad problem
Try to reinstall the touchpad driver.
Get it from this link.
Dec 09, 2008 | Dell F3534 Touchpad
Dell Latiture D600 Touchpad not working!
Have you downloaded and installed the latest glide pad drivers from Dell?
Upon starting your laptop I would enter the bios setup screens and navigate the startup screens using Alt+P to find the pointer settings and set your or check that yours is using Glide Pad only, If you so choose to use an external USB travel mouse, this setting must be changed to Serial only.
Once, you download and install the latest drivers for the Glide Pad, and by the way, the Glide Pad on the D600 series is its only weak link in an otherwise best in class laptop.
To access the sensitivity settings for your Glide Pad after installing the new driver or in your case this may be reinstalling (I have to do this way to often) open Mouse within Control Panel and the last Tab is your Glide Pad. Here you can change a lot of the property values for things like sensitivity and double tap scrolling etc. Your mention of the mouse traveling up and to the right in most case is normal for this laptop.
Here is the link for the Glide Pad driver update. If this link has expired, here is the permanent location. Just click on the download button on this page. Download and move to a unique folder as the file name won't be of help. Move to something like c:\software\Dell\Glide Pad\
Regards,
Worldvet
Jul 24, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite L10 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
