I want to add more memory.
I am trying to figure out what moterboard I have so I can get a compatabile memory. In the PC now is 256MB PC2100 DDR
The markings on the Motherboard are CE SY P4VGM; VIA VT8325. I think it is a SOYO motherboard.
  • 948 Answers
Download and run CPU Z, it will tell you which motherboard you have. If you have memory now, try it in there even if it is PC3200, it will probably work even if it runs at the slower speed. If the computer fails to boot after you put it in simply take it back out.
On the other hand, if you are buying memory make sure you can take it back because some boards are very picky about what they work with.
Posted on Jan 15, 2009
My Toshiba Satellite A15-S129 is very slow How can i make this first. Plz help me at
Saying a computer is slow really is not giving out enough info. The A15's came with 256MB of memory, and runs XP Home - which was barely adequate. So that'd be the first area I'd address: most computers run slow 'cause they ain't got enough memory, and memory is cheap, so it's a crime not to give it an upgrade. If you indeed have 256MB of installed memory, then you should add a 512MB module (it uses laptop DDR PC2100 or PC2700 memory) and that ought to do it.
Mar 02, 2011 | Toshiba Satellite A15-S129 Notebook
I had just one memory module on this motherboard which was kingston ddr, 256mb, pc2100. Then i upgraded my mobo with one stick of pc3200 ddr ram, and it keeps restarting and sometimes it just turns off...
PC 3200 is not supported by this motherboard. It will cause problems. You need to use PC2100 RAM.
Hope this helps.
Sep 27, 2010 | FIC VC 11 Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
What type and how much memory can i put in the MB MS 6577 Ver 4.1?
1GB Of PC2100/PC1600
According to:
Apr 24, 2009 | Computers & Internet
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Memory Upgrade for Compaq Presario 2580US
no 'coz these two memory card differ in size and slot especially when the mainboard doesn't support ddr2
Nov 18, 2008 | Compaq Presario 2580US Notebook
Choosing/upgrading DDR memory
hi there,
i dont see why u should not upgrade to 1gig RAM ... but u should stick to one memory speed ...and Size but if u can try to get the PC2700 - DDR400Mhz memory
Apr 14, 2008 | Syntax SV266A SKA KT266A Motherboard
Please help with memory upgrade problem
This is a common problem with memory. Memory that matches what you have in your computer may not be compatible. The best way to find compatible memory for your computer is to visit websites of manufacturers who produce memory. Here are two sites where you can begin. You will need your computer brand and model in order to search for compatible memory.
or if not:
Apr 10, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
