Question about Kenmore Washing Machines
Washer will fill but will not wash.
It is burning out the fuse , I checked the wiring and could find no problems. I checked the motor and the door switch ok.
  • 15,935 Answers
The ECU is likely bad then.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Fills but won't wash and smells of electric wire burning
No agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
By the way my advice is free cuz God is good!
May 16, 2015 | Amana Washing Machines
My roper washing machine will fill with water, but will not agitate, rinse or spin, but will drain. It makes a horrible noise during all cycles except when filling with water. What is or could be the...
Mar 17, 2015 | Roper Washing Machines
My Amana NTW4600YQ fills but wont wash
Jul 12, 2014 | Amana NTW4600YQ NTW4600YQ 3.4 cu. ft. Top...
W600 fornt load washer does not wash or spin. It does fill and drain fine.
Jan 12, 2014 | Asko W600
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
Nov 22, 2017 | Siemens WFXD5200UC Front Load Washer
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Sep 30, 2012 | Roper Washing Machines
My washing machine fills but the drum is not moving. Also blew the fuse in the plug earlier
Check the wires for damages such as burns or loose connections. If that does not solve the issue check the door switch normally found 2 o'clock on the door frame. See if the lever is loose or may need replacement. If these checked out ok. Have the motor tested. See if it would run minus the load and the circuit.
Nov 11, 2009 | Frigidaire ATF6000ES Front Load Washer
My whirlpool washer fills up with water, and then when it's suppose to agitate it does nothin and smells like something is burning. Is it fixable?
ya it is fixable as you feel some smell it may be some fuse burn out . check fot those things first. if fuses are fine some coils would have burned that would be the problem
Aug 06, 2009 | Washing Machines
At start of cycle, washer drum turns one direction for a few seconds,then spins in other direction for a few seconds and then stops. Next I hear a short buzzer coming from the door area repeat a few times....
There are 4 common trouble makers to consider.
One is the door switch, it can open circuit and stop the washer.
Second is water pressure. If the water pressure is low/poor, the washer will start to fill and then shut off. Check and clean the fill valve entrance screens and also check for any washer screens on either end of the fill hoses.
The third is possibly the most common trouble maker for this type of a complaint. The fuse blows on the motor control board This board can be found on the front bottom on the right side. The motor control board must be replaced when the fuse has blown. Most times now the motor control board is .
The fourth is a bad start switch, sometimes the contacts in the start switch will arc and burn causing starting up problems.
hope this helps.
May 03, 2009 | Washing Machines
Maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
May 22, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
