Question about Motorola Mobility Q Smartphone
I cant get my library music into my ringtones folder
How do i get music from my library to my ringtone folder?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
At first you must have a cell phone which supports all the formats of your library music files. Next step is to connect your phone to PC using the FILE MANAGER (supplies with your phone). Install this program to your PC, connect your phone to it, run FILE MANAGER and start to manage your files!
Posted on Jan 15, 2009
Set my fav tunes as ringtone ?
Ringtones or songs downloaded or copied to your storage card are not automatically added to the ringtone selection menu. You need to go to the Music application and set a ringtone or song in your storage card as your ringtone. To do that top up arrow and Music then tap the three paralel lines at the bottom-left corner of the screen to go to the Library. Play the song that you want to use as a ringtone and on the Playback screen, press MENU and then tap Set as ringtone.
To change the ringtone press MENU, and then tap Settings. Tap Personalize > Default ringtone. The Phone ringtone selection menu then opens and you can scroll through the available ringtones and tap the ringtone you want to use then tap OK.
Feb 14, 2011 | HTC Wildfire Cell Phone
I have managed to get the ring tones to the music folder on my computer, but they don't show up on iTunes so I can get them back on my phone. What did I do wrong? I am using a PC.
Make sure you go into itunes, click file > add file to library, and add the ringtones back into itunes.
Also in itunes, it should show a "Ringtones" section on the left under library, if it shows them in there, you only have to sync it to your phone. If these ringtones show up under music however, they are the wrong type of file.
Feb 12, 2011 | BLACKOUT LABS Ringtone Designer Free
How do i set my music as a ringtone on iphone 4
It's a very tricky method. Follow these step precisely, and you should have your own custom ringtone like I have.
Please rate this solution if it helps you.
1 Open iTunes.
2 Find the song that you want to make into a ringtone.
3 Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
4 Write down the start and stop times of the clip.
5 Right-click the song and select "Get Info."
6 Click the "Options" tab.
7 Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., x:xx) format.
8 Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
9 Click "OK."
10 Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
11 Right-click the ringtone and select "Delete."
12 Click on the "Keep Files" button.
13 Find the file. It's usually in your User folder under "Music > iTunes > iTunes Music" and under the band's name. It will have an extension of m4a.
14 Replace the m4a extension of your ringtone with m4r. You can either double-click slowly to rename your file, or right-click and select "Get Info" on a Mac or "Rename" on a Windows PC.
15 Click "Use .m4r" or the PC equivalent when the system warns you that the change may affect the use of your file.
16 Double-click the ringtone file. ITunes will automatically add it to your ringtones folder in your iTunes Music Library.
17 Connect your iPhone and sync your ringtones.
Oct 27, 2010 | Apple iPhone (16 GB) Smartphone
Help!!!! i cant put music into my huawei m750
your m750 should of came with a usb cord. the is site i use is www.zedge.com and what i do is download my ringtones to a specific folder so that i can find it. first plug your usb into your phone and then into the computer..exit all that pops up and even if you get a message to the right that will say driver could not install, still close it out then download what ringtone you may have and then go to computer removable disk k or what ever removable disk that is not normally there and double click on it and it will put up what is on the phone and then go to the folder in which you save the ringtone and right click the ringtone and then send it to the removable disk k and then it should show how it's being transferred to what is on you phone move the ringtone to your music folder and then close out the pages go to your phone and click files and go to music and it should be there
Jan 30, 2010 | Cell Phones
Pantech p7000 custom ringtones
In the settings folder under profiles you have to have yours set to normal and then go back and set the file as a ringtone.
Dec 18, 2009 | Nokia 1661 Cell Phone
I have problem with my ringtone cellphone nokia n97
hmm..try resetting ur mobile with basic core "12345" or ur code if u modified it..then try..even if it not works..keep ur songs in Digital folder and ringtones under Simple both under Sound Clips n try setting the ringtone..dont keep ringtone while is music player..go to profiles n set coz its effective
Dec 09, 2009 | Nokia N97 Cell Phone
Ringtones
you have to format the memory card first to the phone.. easiest way to do this is to take a picture from the phone and transfter it to the card...
at this point the card will now have folders associated with the phone on it..
if you put your sd card into your computer and see any files that are not in a "my_pix, my_flix, my_ringtones etc" folder, drag them to the appropriate folder and you will be able to access them through the phone
so if you wanted to do ringtones drag the music into the ringtones folder. if you wanted music drag it to the music folder
Nov 10, 2009 | Casio G''zOne Type S Cellular Phone
Lg Shine Flip Ringtones
-Make sure the file is appropriate.. 30 seconds or less, mp3 format
-When you add your music to the memory card, it shows up as a song but not as a ringtone right?
The solution is to create a different folder rather than using the “Music” folder the phoneautomatically creates for you. Transfer your music to this new folder you’ve created. The ringtones should show up as long as it fits the requirements
Hope this helps
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Setting personal music as ringtone
open your music files select your music to be used as ring tone. hit menu. then use as ringtone
Dec 07, 2008 | HTC G1
Motorola Mobility Q  Smartphone Logo
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
