Question about Tappan TGF320 Gas Kitchen Range
I have a tappen gas range. The oven won't light. I replaced the oven gas control. Still doesn't work. I checked for the 3 vac volts to the gas control and I am not getting a reading.
  • jeff40ky Jan 17, 2009
    Thank you very much! The igniter fixed the problem. It is nice to know there are people like you to help people like me. Thanks again!
  • 318 Answers
Jeff, see my comments on your other question. i think you have a weak ignitor.
Posted on Jan 15, 2009
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
The oven doesn.t go on, I see the ignighter turn on but the gas won't light.
Hello Jim,
Believe it not the igniter is the problem,yes indeed it is coming on yet it is not getting hot enough to allow the gas valve to open. By replacing the igniter with a fresh strong one, the oven will work just fine.
GENE
Nov 14, 2011 | Kitchen Ranges
My broiler doesn't work in my JennAir S136 range and I think the problem is the selector switch. How can I confirm this?
To do that you could check if the correct power is going to broil element.That can by TURNING OFF CIRCUIT BREAKER, remove door by opening to appx 30 degree position where is shold stay open,pull off door,remove broil element and attach a volt meter set to measure at least 240 volts ac and attach the meter leads to the wires on broil element, restore power set controls to broil and check for 240 vac at element. If 240 vac at element it's the element thats defective, if 240vac not present the selector switch is the problem, espically if bake works
Good luck,i hope this helps ya diagnose your oven
Gene
Jul 31, 2011 | Ovens
Gas oven(tappen) with broiler draw. oven will not light, no pilot
if this is fairly new, there is a hot surface ignitor near the back of the burner in the bottom part of the oven. This can go bad. There is a connector that can be pulled apart where the ignitor meets the wiring harness. Ohm out the ignitor or have someone with a meter ohm it out. There should be resistance and not open. If open the ignitor should be replaced. If you have a broiling element, turn that on. If the broil element comes on then the ignitor is almost for sure the problem.
Nov 21, 2009 | Ovens
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Presure regulator
try checking on the regulator behind the pull out drawer there is a switch on there that will turn off the gas flow to the oven
Mar 25, 2009 | Kitchen Ranges
Smelling gas but not lighting
I've had ignitors fail that way, they don't always just burn into an open circuit. I'd advise replacing it.
Jan 12, 2009 | Tappan TGF320 Gas Kitchen Range
Oven will not light but smell gas
i think you probably have a weak ignitor. does the ignitor glow orange?
if it does, or i should say when it does, just tap lightly on the gas valve and see if that causes the gas to flow into the burner and then light.
you can use the handle of a screwdriver to tap with and it wont need to much force.
if this does work, then just replace the ignitor. when they get weak they will glow, but wont draw enough current thru the gas valve to allow it to open. your valve does get voltage but it opens when enough current draw opens the bi-metal portion of the valve to allow gas to flow.
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
Tappan TGF320 Gas Kitchen Range Logo
113 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De GO PATS
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
