Question about Trendware TEG-S2600i 24-Port Ethernet Switch (TEGS2600I)
Password was changed
I have a Trendnet TEG-2400/2600i SNMP Switch and the original password 123 was changed.
How can I reset by hardware or anyway.
Thank you
  • Jose Duran
    Jose Duran Jan 15, 2009
    This Item doesn't have any reset or hardware reset button, but thank you anyway.
    Scholar:
  • 108 Answers
If you forget the password, press the “Reset” button in the front panel
of the Switch, the current setting includes VLAN, Port Setting… etc.
will be lost and the Switch will restore to the default setting.
Posted on Jan 15, 2009
How do i cable 10 computers, a docsis 3.0 modem, 8 port edgewater 881 router and 5 port trendnet TEG-S5G unmanaged switch
Connect 7 computers to the 881 router. The last port on the 881 router go to Trendnet switch. Connect the last 3 computers to the Trendnet.
Feb 11, 2013 | Computers & Internet
Can't remember my password
If you have NOT changed the default password, that is:
Manufacturer Model Protocol Username Password BELKIN F5D6130 SNMP (none) MiniAP BELKIN F5D7150 Rev. FB MULTI n/a admin BELKIN F5D8233-4 HTTP (blank) (blank) BELKIN F5D7231 HTTP admin (blank)
If you have changed it, just reset the router and use above passwords.
Aug 02, 2011 | Belkin Basic Wireless Router
In order to use WiFi in my home, I need to know/change my router password. Id there any way to reset and renew my password?
Normally on the back of a router there is a reset button that will set the router back to the way it was when you first removed it from the box. Hold this button with a pin or tip of a pencil for 10 seconds and then go through the original setup process you went through. This is where you can setup your wireless password and your router password as well.
Check out the Trendnet web site for more detailed instructions if you do not remember.
Good Luck.
May 09, 2011 | Trendware TEW-632BRP Wireless Router
How to reset Trendnet TEW 652BRP Wireless N Home Router
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 12, 2011 | Trendnet TEW 652BRP Wireless N Home Router...
I am the owner of Trendnet TEW634GRU. I have a problem for installation. When I access to the web page http://192.168.10.1, the default admin: admin and the default password: admin doesn't work to log in....
make sure you have reset the router first.
It sounds like the password was changed (as it should be)
The reset will put it back to factory specs and you will start fresh with all the settings.
Dec 24, 2010 | Trendnet TEW634GRU (Version v10R) 300Mbps...
Reset password
What password are you referring to; Wireless Security or Web password to access the Router's interface?
If it's the 2nd; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password. Click on Password then change the default password.
If it's the 1st; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password (put you correct password if you change the default password).. Click Wireless on the left, Enable Encryption WEP or WPA; for WEP 64 bit you will have to use 10 HEX, meaning 0-9, A-F (e.g. common is phone number). If WPA; password can be set from 8-64 characters long.
Angel .
Jun 30, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
Resetting the switch
Heres the online manual for this unit,
http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=4938
Its full of info that covers just about everything youll ever need for thiis unit
Hope this helps,MISTERDJ
May 07, 2010 | Trendware TRENDnet TEG-S2600i 26 Port...
How to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Impossible Firmware upgrade
That path should be location of the file you downloaded from trendnet site. The password is set up password for router. Hope you remember that one.
Nov 08, 2007 | Trendnet TEG-224WS 24-Port Ethernet Switch...
Trendware TEG-S2600i 24-Port Ethernet Switch (TEGS2600I) Logo
311 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
