Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter-
Upon pressing the two buttons to remote start my truck, the solenoid engages the starter motor and the engine starts but shut down after one second of running and repeats the process two more times. the left parking light stays on also. The same thing is happening with mine.
  • furinol Jan 15, 2009
    same thing, I haven't noticed a light staying on but the start/stop 3x thing sucks.
  • 26 Answers
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Posted on Jan 16, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Starter continuously engaging. Its n Starter continuously engaging.
When you say you replaced the relay, do you mean the starter solenoid? I would suggest the solenoid is duff or incorrectly connected.. A starter system works by switching on the ignition, pressing the starter button, the solenoid closes and allows power from the battery to turn the starter motor. When your engine has started you release the button the solenoid opens so no power is going to the starter. Re check the solenoid wiring, when you press the start button do you hear a click? A starter motor simply cannot work if the solenoid is open as there is no power available to it.
Dec 22, 2014 | Motorcycles
Why does the starter stay engaged on my 99 Chevy suburban when I use the remote start
Check the batteries. If remote is the one that came with it. could be wore out.
Nov 21, 2014 | 1999 Chevrolet Suburban
I have a 2000 toyota celica gts and it wont start or turn over the starter will make like a whinning sound but its not trying to crank the engine maybe its the starter but just in case its not anybody have...
Likely either the starter or solenoid. Solenoid is a combination of relay and actuator, pushing the starter's gear into engagement with your flywheel.
Oct 28, 2014 | Cars & Trucks
I have a Prestige Model APS-775 3 Button Remote Start Security System made by Audiovox in a 2000 Tundra. My problem is that since I got my truck back from the frame recall (they replaced the entire...
The starter fails to disengage? Do you mean that the starter engages but the vehicle does not start? If so, there could be an issue with the immobilizer bypass. The vehicle is not seeing the transponder from the key/bypass, thereby not engaging the fuel pump. One way to confirm this is to put the key in the ignition and then remote start the car. If the vehicle starts, then you have successfully diagnosed the problem.
Or, do you mean that the vehicle starts and shuts down after 5 seconds. If so, the tachometer wire may have been disconnected during the repair service. The tach wire is green with an orange stripe and it may still be hanging (unattached) in the engine compartment. Try tracing any wiring harness coming through the firewall into the engine compartment on the driver's side that has an "aftermarket appearance", meaning that it may appear out of place in association with the factory wiring harnesses. Make sure that all the wiring is connected. The tach wire is black at the diagnostic connector on the drivers side of the motor or, you can use the uncommon wire at the coil.
Mar 10, 2011 | APS95BT3 Car Transmitter with 3 Button...
Hi I have a 2005 ultra with 58 k miles, when started to ride or warm it up, it starts fine then at no given time you hear a chatter noise as if the starter is engaging and then disengaging. Could this be ?...
If you'll look just behind the rear cylinder, there is a black thing with a large cable running to it. This is the starter on your bike.
I could be your starter hanging up. When you press the start button, the jackshaft is pushed out by the solenoid part of your starter and it engages the ring gear on your outer clutch drum. The starter motor starts up and turns your engine. Once the engine fires, the jackshaft is now turned faster than the starter motor can turn it and the starter clutch allows it to "free wheel" until you let off on the start button. Once you let off on the start button, the solenoid demagnetizes and pulls the jackshaft out of engagement with the ring gear.
If you think the starter is hanging up, you need to take it to a qualified mechanic and have it checked. Since you don't know where the starter is, I would be hesitant to tell you how to try to repair the starter. Have it checked out before the starter clutch locks up and the starter is destroyed and cause damage in other areas as well.
Steve
Dec 27, 2010 | 2005 Harley Davidson FLHTC - FLHTCI...
The starter has been tested as good, but the car wont start, any ideas?
load test battery
check for tight, clean connections at battery
check neutral safety or clutch safety switch
check starter relay
check ignition switch
check engine and chassis grounds,
below is from the autozone.com site. click on red X's to view files
Four types of starter motor are utilized depending upon the vehicle transaxle and assembly plant location. Manual transaxle equipped vehicles utilize a conventional starter motor which consists of a yoke, an armature assembly, an overrunning clutch assembly, a solenoid, a commutator end cover, a brush holder and a pinion drive lever. Automatic transaxle equipped vehicles utilize a reduction type starter motor which has, in addition to the components found on conventional starter motors, a reduction gear and shock absorber assembly.
In the basic circuit, the solenoid windings are energized when the ignition switch is turn to the START position and the clutch start/neutral safety switch is closed. The resulting plunger and shift lever movement causes the pinion to engage the engine flywheel ring gear. This movement also causes the starter solenoid contacts to close.
With the contacts closed, the starter solenoid provides a closed circuit between the battery positive terminal and the starter motor. Because the starter motor is permanently grounded to the engine block, the circuit is complete and cranking occurs as soon as the starter solenoid contacts are closed.
When the engine starts, the pinion is designed to overrun and protect the armature from excessive speed until the ignition switch is released from the START position. With the ignition switch released, a return spring in the solenoid assembly forces the starter solenoid contacts open, breaks the circuit between the battery and the starter motor, and disengages the pinion. To prevent prolonged overrun, the ignition switch should be immediately released upon engine start-up.
See Figures 1 and 2
Fig. Fig. 1: Electrical system diagnosis - No cranking condition
Fig. Fig. 2: Electrical system diagnosis - Slow cranking condition
Oct 15, 2010 | 1994 Geo Metro
Yamaha snowmobile starting issue
sounds like the starter is sticking!
Dec 09, 2008 | 2008 Yamaha XT 660 Z Tenere
we have a viper 600hf and it has recently started draining thebattery and it won't stay charged.
Feb 05, 2008 | Viper RCVGC022 Remote Control
Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Dec 01, 2007 | Scytek 2000RS-M Remote Control
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
855 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
