Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bottom Dishwasher arm not turning
I have a Bosch SGS43A52GB/04 dishwasher and the bottom arm is not turning and no water is entering the arm. I have cleaned the arm, checked the impellor and sump filters and there was nothing to be found. Is there a mechanism in the sump that controls the flow between the top and bottm arms as the top arm has water flowing and is turning?
  • Ben Heptinstall Jun 17, 2007
    As far as I can see there is no water coming out of the bottom suplly tube. The model I have does not have a half load switch.
    There is a single outlet from the impellor that divides somewhere to the supply for the top and bottom arms. Before I start trying to clear a possible blockage does anyone know if this is a simple Y type split in the pipe or is there a control mechanism that may be damaged by forcing a flexible rod through?
    Sergeant:
  • 236 Answers
Have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Posted on Jun 16, 2007
Water is not flowing into the dishwasher. Initial problem was that it was not draining. It now drains but now it will not pump any water into the dish washer.
I have this same problem! Just started happening. My Bosch drains fine but only a very little water is entering the unit and it seems to be coming thru the arms on the bottom not the top. Help! I checked the arms and they are clear, drain is clean.
Apr 16, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
No water enters the dishwasher when its turned on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
Sgs43a52gb Water is not filling the machine
heatman101
May 17, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Not cleaning dishes
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Nov 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bottom spray arm not turning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
rthd
Jun 09, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My Bosch Dishwasher doesn't clean
Check the following to address this issue--
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
Jun 02, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bottom Spray Arm Not Rotating
check to make sure you are getting enough water entering the dishwasher. If you add a liter of water, does the water arm turn then? If so, you may have a faulty water valve that is not allowing enough water to enter to turn the spray arm. Hope that solves it :)
Feb 26, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Clogged dishwasher arms
Our Bosch has a round knob in the center of the arm, under the basket. ROtate it 90 degrees, and the arm drops away and can be cleaned.
Jan 16, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch sprayer arm found in bottom of dishwasher
how many pieces is the sprayer arm and how many sprayer arms to do you have 2 or 3?
Aug 22, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch dishwasher sgs43a52gb
try http://www.bshappliancecare.com/Bosch/boschspares.html
it's pretty flaky and I didn't work when I tried to download a manual for my SRS43A02GB/08, but the parts-lists do.
If you go to the 'Launch the spare parts eShop' and enter your model number (you only quote it partially above, so you then need to select the particular model), you can see the exploded parts diagram - click right-hand icon 'print all pages' to get a pdf of all the exploded diagrams. You can order from here too and they seem a lot cheaper than alternatives, but I haven't actually bought anything yet.
May 20, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
363 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
