Question about The Learning Company Learn to Speak English 8.1 (772040814748)
Cannot install "learn to speak english 8.1" in my XP pro OS.
The problem comes when in the beginning, i hit the "install" button of the software( i have the cds.), when i press "install", the screen goes still and no loading takes place.
    Problem Solver:
  • 14 Answers
Just wait for a minute or two, maybe your CD drive is still reading the content of the CD
Posted on Jan 15, 2009
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
Very difficult to understand others speaking English.
It is normal to find it hard to understand at the beginning.
In order to improve your listening and understand better I advise you to listen TV broadcasts in English with subtitles in your native language.
By time you will improve your listening skills.
I hope this information helps.
May 11, 2011 | The Learning Company Learn to Speak...
I can not install Learn to speack English Version 8.0 on windows 7
Try running the program in compatibility mode. Right click on the icon used to start it, go to compatibility and change it to Windows XP. If this doesn't work, the program is not capable of running in Windows 7 so you will need to downgrade Windows or upgrade to a newer version of the Learn to Speak English software.
May 04, 2011 | The Learning Company Learn to Speak...
I would like to run learn to speak english (setup file version 2.0.71.0) under Windows XP. How can I do that. Previously it was run under windows 95. TAhn you in advance
Hi, welcome to FixYa.
Windows XP provides such compatibility mode to run old program in Windows XP. Believe me, I've tried this and it works, in my case I installed my old game The Lost Mind of Dr Brain which developed for Windows 3.11 or Windows 95.
To do it, you just need to locate executable file of your program. Then right click on it, choose Properties. Then go to Compatibility tab, checked "Run this program in compatibility mode for:", then choose Windows 95. You may also need to thick the "Run in 256 color" and "Disable visual themes" check box.
I hope this can help you out. Thanks for visiting FixYa.
Mar 14, 2011 | The Learning Company Learn To Speak...
My disk #1 has VIRUS in D:installBroadcastDSSAGENT.EXE it could not be delete or install the program Learn to Speak English 8.... what to do?
I would contact the manafacturer for more information. If your disc shows a virus on it I am sure that they would like to know so that they can track and see if others are having the same issue. They also will be the ones to resolve it due to the fact that their product caused the issue.
Apr 01, 2010 | The Learning Company Learn to Speak...
I am trying to install 6.01 of learn to speak German. It worked fine on my old win 95 machine but doesn't recognize the systems on my xp machine, not even QT 7, and chrashed during install, locking up with...
It may not be compatible with XP. Look on the back of the case and check which OS it is for. Sometimes the websites that support these have a patch for when you upgrade. I have had this problem with some of my software every time I've upgraded Operating Systems.
Sep 18, 2009 | The Learning Company Learn to Speak German...
Learn to speak english 8.1 not install xp professional OS laptop
you could check here for more inputs and issues discussed which helps you...
http://support.selectsoft.com/products/L/LLLEAEN81J.htm
Jul 08, 2009 | The Learning Company Mavis Beacon Teaches...
Problem installing all learn to speak software
If you have Vista try to right click the install file and select "Run as Administrator" and see if it works..
Mar 11, 2009 | The Learning Company Learn to Speak...
The Learning Company Learn to Speak English 8.1 (772040814748) Logo
224 people viewed this question
Top The Learning Company Computers & Internet Experts
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
