Question about Sony Playstation 3 (PS3) Console
Ps3 xmb glitch
Here is a video I made to show what is happening but this video was made before the text began twisting and becoming unreadable.
http://www.youtube.com/watch?v=WefMpkuL5Tg
I have had this problem since 2.4 my text is twisting and my icons are stretched out. I can still play games and movies fine but all the text even the keyboards text twisted or is stretched and unreadable. All images such as on the store or background are stretched out to.It's getting worse now right when i turn my ps3 on its messed up or in under 30 sec it will mess up. Also the in game xmb does the same thing now.
  • punkerjw Jan 15, 2009
    Just to be clear I meant firmware 2.4
    Also it is not overheating. I have it in an open space and it's quiet. I have tried hooking it up with different cords also and to different tv's. So it has to be a glitch when i updated it at sometime and it continues to get worse.
pauliemigs
  • 4 Answers
SOURCE: PS3 DOLBY DIGITAL ISSUES
In the PS3 menu, open Settings > Video Settings > BD/DVD Audio Output Format (HDMI) or (Optical Digital) depending on which one you are using. Set the type to to Bitstream (Linear PCM does not send the DD stream through).
Posted on Jan 18, 2009
Big Hev
  • 64 Answers
SOURCE: My ps3 won't play ps3 games anymore.
I had the same issue. I had to send it to PSR Repairs to have it checked out. They ended up replacing the hard drive & the laser lens. According to them, both those components contributed to the freezing up & inability to turn back on. Before I sent it in, I was able to get it to turn back on by holding down both the power button & eject button simultainiously. Lie it beep once, then double beep... Once you hear the double beep, release both buttons. A menu will come up giving you 6 options. Try option 3 first! you wont lose any saved items with this option. If that doesn't work, you will need to use option 6. This will delete ALL of your saved items, but there's a chance that you may not have to have your console repaired. You can retrieve trophies, games & demos from the PlayStation Store. Good luck! If I can be of further help, comment me back under this heading!
Posted on May 12, 2009
benwabnick
  • 2404 Answers
SOURCE: Ps3 disc drive not working.
You've done everything I would have done honestly. Take a can of air and blow it into the drive to make sure dirt or dust isn't on the laser which could affect if it sees discs or not.
The better thing to try if you are good at opening up your ps3 and then removing your drive and opening that is to take a damp q-tip with a bit of glass cleaner and clean your laser in the drive gently. Then put the drive back together and hook the cables back up to the ps3. You can leave the cover to the ps3 off for this step. Turn on the ps3 and try different blu-ray, dvd's, music cd's, game discs, etc. If it still doesn't read any of them then either the laser or the drive i bad. If it reads some discs and not others then its a weak laser and the laser would need to be replaced.
If you have to replace the laser or the drive, you can do a search on Ebay and usually find them fairly cheap.
Hope this helps and let me know if I can be of further assistance.
Posted on Jun 21, 2009
Killen4fun
  • 46 Answers
SOURCE: My PS3 won't play an disc games, the disc icon doesn't even show
Sadly there currently is no fix for this problem. I've also had this same problem and contacted Sony about it.
You need to send it in to them to get it serviced. You can do this at:
www.us.playstation.com/Support/PS3
or
uk.playstation.com/help-support/ps3
If your warrenty has expired it will cost around $180.
Hope This Helps. Also be sure to rate whether it did or not.
Posted on Jun 25, 2009
  • 105 Answers
SOURCE: PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
Posted on Jul 14, 2009
When i put my ps3 games in they don't show up in the menu. nor do they auto start. the same thing happens with movies?
You can enable or disable auto run in the settings area on the XMB, but I've never heard of the disc not showing up at all. Even if the disc was unreadable, the PS3 would say "Corrupted Data" or something. You should go through your PS3's settings and see if there's anything that's not right. Maybe there's a "Hide disk" option enabled. Sorry I couldn't help more.
Apr 10, 2011 | Sony Playstation 3 (PS3) Console
Hello When playing a game i bring up the xmb to quit the game and it freezes flashing between game and xmb screen. When this happens the only solution is to turn it off manually. Please Help
PS3 freezes between game and xmb screen are suffering to many gamers. But trouble shooting is not easy : Most gamers think there are CPU overheat problem but actually not the reason. You need some killer methods to fix and test it. Do you know it's just waste your time and money if you send to somewhere repair - because the same problems will be back after then. The best way is to learn the repair techniques of yourself.
There is a PS3 DIY Repair Guide: The author use text and video to show you how to use your hands to open your console and do some maintenance and fixes, at last you are amazing that why you can do that yourself. The best part is you can help your friends too!
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
When do you know when you need to change you hard drive for ps3
  • Wired Slowdown / Slow Motion effect using xmb.
  • Games Glitch that triggers an automatic lockup / ps3 reboot.
  • Installing a game, it hits 100% status then does nothing... Can bring up xmb, chose exit, it restarts PS3
  • Running Option 4 in Recover / safe mode reports something along the lines of database corrupt, do you want to recover database, instead of just "do you want to recover database" after you already attempted to repair them using this utility.
  • Game tells you downloaded dlsc is corrupt (DragonAge)
  • You hear odd noises from the PS3... that not the fan.
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
XMB not showing up
Sounds like your cpu has overheated and separated from the board, causing it to freeze before loading the xmb.
0 false 18 pt 18 pt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;} Try CPR in New York City. They are faster than the manufacturer, and cheaper! They have a usual turnaround of 1-2 business days. And if you become a fan on their facebook page, mention it and you will get a 10% discount.
Here is the link to their facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
Jun 03, 2010 | Sony Playstation 3 (PS3) Console
During music playback I want to play slide show but when I press the PS button I only get message asking if I want to quit rather then going to the XMB menu. Same thing happened when I tried it with my...
The slide show is like Playstation Store you can only exit it not go to the XMB menu. You can just put on a song and press R1 on your pictures to pass them instead if you want to do that.
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
I have saved all my data from my 60gb ps3 onto mem stick but cant download to my new slim ps3 helpppppppp
what type of data if its game saves you accually have to goto game saves on XMB and look in mem stick then hit triangle to copy them to the HDD. videos and other stuff should just show up under videos. basicly everything you copied over you have to goto that area of the XMB to copy it back.
are you seeing the data just not able to copy it or what?
Sep 23, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
PS3 XMB menu doesn't show up.
That's not too hard to fix.
Check out my guide here:
Pay attention to #3.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
267 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
