Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dishwasher stops inbetween rinse and dry
I have an FDW60 dishwasher and the it has started flashing lights 4 (fast)and 6 (delicate) before finishing the wash. The dishes are clean and they look rinsed but it is not doing the drying stage. The trouble shooting manual does not list anything about lights 4 and 6 flashing and Hotpoint want to charge £90 to fix it even though it is under 2 years old. Does anybody have any ideas what this lights sequence means and how to fix it? Thanks
  • Anonymous May 06, 2008
    Hi I have the same problem lights 4 and 6 flash meaning there is an issue with the heating unit. my FDW (poor excuse for a dishwasher) came with 5 years parts warranty, but you have to use them to fix it. this means £95 call out and free parts....or they have offered that I pay £15.90 per month (for 10 months) for a 1 year protection plan (£159)...and all for a dish washer that is only 2 years old, I won't be buying a Hotpoint again........
  • Anonymous Mar 16, 2014
    when I start the machine on a "normal" wash, it goes to "fast" & "delicate". Dishes come out wet and cold. How do I rectify/reset this problem
    Problem Solver:
  • 7 Answers
Hi
if the problem faults within the first 1 minute the first check the connections on the main module behind the control panel,as you you look at the control panel there is a pink connection to the left,if this looks like it has got hot then theres yopur problem(you will find that the joint on the board has come loose from the soldered joint,module requires replacing.
if this connection looks ok then the heater is open curcuit and will require replacing.
Posted on May 18, 2008
I'm having the exact same light's flashing... have you got any further with this?
Posted on Sep 10, 2007
Hoppoint have e-mailed me that these lights ( 4 and 6) indicate that there is a fault with the heater circuit. But I have got no further than this with a repair. Not sure what to do. Please emial if you discover any further information on a repair. My dishwasher is under 2 years also.
Posted on Jul 01, 2007
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Fdw60 is flashing fast and delicate lights
The code is a10 this is normally a heating issue but could also be a foaming problem which could also be your poor washing results put a cleaner through with a lime scale remover
Jan 24, 2014 | Hotpoint 24 in. FDW60 Free-standing...
My fdw60 hotpoint dishwasher seems to start then the fast light and the delicate light flash and it stops. Please help.
Have you tried cleaning out the filters in the base of the machine? Also make sure there is no bits in the filter sump. Then give it a clean using a dishwasher cleaner.
Nov 10, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint SDW 60 dishwasher stopped working
The error code is for the 'heater circuit' before getting a new heater check the thermister (on the end of a black wire hanging off the main control board ) as the either dryjoints or comes loose
Dec 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Fast and delicate lights flashing.
No, do not repair this, everyone who has purchased this model should demand a refund !!!!The problems are endless.
Apr 24, 2008 | Hotpoint 24 in. FDW60 Free-standing...
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Not rinsing or drying
This appliance should be on warranty; call seller.
Nov 06, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
876 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
