Question about Samsung CLX 3160fn All-In-One Printer
Noisy long high pitch whining fan
Noisy whine or high pitched fan that is very irritating. I went back to Stapels and the machine on the floor did not do it, but they acknowledged that several other customers have had the same problem. In my small office the sound is so loud as to the point of returning the unit. It is still under warranty. Any help before return appreciated' Thjanks Rick
  • Rick Platt Jun 18, 2007
    I changed the toner cartridge as suggested and would say the pitch isnt quite as high and is now somewhat barable. I know we want absolute silence but need to be realistic.
    Thanks for your help.
    Rick
    President:
  • 2,072 Answers
You will have to remove the cover over the fan with the machine unplugged. Clean the fine and remove the label from the center of the fan, then the rubber center cap, and drop some really highly refined oil into the bearing.
Those bearings get dry and noisy.
Then reseal the bearing area. That will make it pretty quiet.
Posted on Feb 26, 2008
  • 186 Answers
Try changing the toner cartridge. I have seen this problem before.
Posted on Jun 16, 2007
What is making this 08 caliber 2.0L sxt cvt have a High pitched whining sound at idle and driving?
Possible bearing in one of the drive pulleys. I have changed numerous alternators for this noise. Take the belt off and start the car. If the noise goes away you know it will be pulley related and not transmission related. If noise goes away, spin all pulleys by hand to determine the defective/noisy one
Aug 03, 2015 | 2008 Dodge Caliber
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
High pitched whine
Could be the fan which is causing this. If the machine is running hot then the vents are likely blocked, which will cause the fan to work harder trying to cool the system. If so the case needs to be opened to clean the vents, fan and heatsink. Check there is no disc spinning in the CD drive, as that can be noisy. It could possibly be the hard drive failing, back up any important files just in case!
Mar 31, 2012 | Computers & Internet
My HD61LPW42 makes a high pitched wirring noise after it is on a few seconds sounds like the fan is rubbing against something but doesn't appear to be. The picture quality is still good and the tv...
this might be a noisy color wheel . this is a motorized wheel that produces the color in the set. it could be something else because of your statement of picture is ok. if it the color wheel the set will eventally shut down. this part used to be avalible and fairly easy to replace. it has got harder to locate. The other possibilites includes a small leaky capacitor in the powers supply but that is more like a whine. a tech would have to take the back off and locate the noise.. i believe this unit might have 2 fans and a color wheel. three moving motors.. anything that moves eventally dosnt
Mar 22, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
D52w23 rca makes an awful loud high pitched whine
This is a coil, now a NOISY coil.. It is a common problem, and happens often. The whine is caused by current passing thru the copper windings and making them vibrate! A commonly accepted repair for this situation is to squirt some regular old super glue into the copper windings and let it harden for a few minutes..Viola! no more whine!
Jan 28, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
Whining diff 1986 silver spirit
Height control action noisy, emitting squawks when operating. Air in heigt control system. Bleed system.
Jul 13, 2008 | 1991 Rolls Royce Rolls Royce Silver Spur
Samsung CLX 3160fn All-In-One Printer Logo
211 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
