SOURCE: loud humming noise (vibration) from freezer
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
