Question about Philips 150S (White) 15" LCD Monitor
It started failing, now is dead.
In the past, my 150s monitor sometimes was failing. It didn´t . Just didn´t switch on, or sometimes switch for 1/2 second and swiched off. Other times swithed but the screen got totally blank, keep white while image disappeared and then switched off. The problem disappeared when putting the panel on a dry enviroment, or on a place where the sun gives it some heat, so I thought was just humidity. Now, doesn´t switch at all. Anyone knows posible solution?,
  • jose ferreira Jun 17, 2007
    It is 4 years. Maybe some problem with humidity? If I buy a new one, any problem with have it in the sleeping room?
    Genius:
  • 2,985 Answers
If it is over a year or so old - simply replace it There are usually no economic repair solutions.
Posted on Jun 16, 2007
  • john ash
    john ash Jun 18, 2007
    Keep it where it is warm and dry any room will do
    so long as it does not keep you awake at night - in which case switch it off or turn it to the wall ;-)
SOURCE:
No start ,dead
Hi alonzot,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Apr 25, 2011 | Soyo DYLM1798 Monitor
My flatscreen monitor (HP w19b) kept powering down. I would push the on button, and it would go on then power down after 10 seconds. This morning it wouldn't go on at all for about 1/2 hour, then started...
Hi sir, try to check for possible leaking or bloated filter capacitor in power supply board. That symptom might be caused by insufficient current draw from power supply source. Try to check sir. Maybe it could help. Thanks!
Feb 14, 2018 | HP W19b LCD Monitor
I have monitor Philips 150S. It is increasing brightness up to 100% when switch on the monitor and unable to remove that brighness picture. Monitor hot keys also not work. I pluged this to a lap top but...
mohanjith, First thing to investigate is the lcd monitor internal power supply for failed electrolytic filter capacitors on the power supply circuit board. If swollen and leaky, then you might try to replace the bad ones with new ones. Visit YOUTUBE for video clips to see if you can do the investigation/repair. Search YOUTUBE using "lcd monitor disassembly" and "lcd monitor repair"!!! Lots ov video clips to learn how to do DIY repair. 12fixlouie
Nov 10, 2010 | Philips 150S (White) 15" LCD Monitor
Hi Ladywin, I have question regarding your fix on convergence problem pasted below: Is the reason to replace STK***-110 to STK***-120 or 150s, is because theyare more durable? "Start out with...
She does not appear to be here but I can assist you.
You have convergence problem? Give me brand and model and I will tell you what is needed.
SD TECH
Sep 01, 2010 | Televison & Video
My philips lcd monitor 150S is failing me. I switch it on and then it shows and after few seconds the screen is black (meaning its off no picture) Then I off it and on again and then got picture for 2...
Check connections are good. Check pins in plug. Check with another monitor. Check with another cable.
If all tests are satisfactory then replace faulty monitor. End of life!
Jul 13, 2017 | Philips 150S (White) 15" LCD Monitor
Philips 150S screen turns on for 1 sec. and then gose dark???
nyounger4242, Very common problem!! learn to do flashlight test to evaluate "switch-mode-power-supply" status. Read my FIXYA profile to find out all you need to know about Black, or Black and Blank lcd screen fixes and the options you have. Your monitor NO DIFFERENT than any other CCFL Back-lit LCD monitor in it's basic design and operation!! Good luck with repair. Use warranty if possible. Read, Read, Read, before you do anything!!!! 12fixlouie
Feb 04, 2010 | Philips 150S4FB 15" LCD Monitor
Power window systems failing in past few months. 3 of 4 now dead.
before spending alot of money on windows motors, try to take out the switch in the door handle and spray contact cleaner in the switch.. sometimes if you use alot of armor all on the door panels it will work its way into the switch and make it dirty.
Aug 14, 2009 | 1999 Jeep Grand Cherokee
I lost power supply for philips 150s LCD monitor
Check with cables2go.com. They sell just about all replacement power supplies and any cables you might ever need. Hope this helps.
Mar 14, 2009 | Computers & Internet
LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Jan 06, 2008 | Samsung SyncMaster 205BW LCD Monitor
Philips 150S (White) 15" LCD Monitor Logo
173 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
