Question about Acer Aspire 5672WLMi Notebook
Laptop won't switch on
When I go to turn on my laptop, the power button flashes for about 3 seconds then the laptop turns off again.
  • Anonymous Mar 01, 2009
    Mine does the same thing. The battery light flashes for about 3 seconds when I try to turn it on. It flashes about 3 times. And then the laptop wont turn on.
    New Friend:
  • 83 Answers
How many times does it flash b4 turning off
Posted on Jun 16, 2007
SOURCE:
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
I have a hp netbook laptop and it was working earlier but when I opened it it flashed my login screen and shut off and I can't get it back on and when I press the turn on button the charging button...
Remove the main battery and press power, sometimes this will solve the problem. If not, remove one stick of ram and power on, if not remove the second one and replace the first and try again. If no result it is probably a motherboard issue.
Mar 10, 2012 | HP Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My compaq CQ 61-420 US notebook won't turn on It was on and we left the room for a few minutes and came back in and it was off and won't come back on the 3 lights in the bottum left flash 3 times...
Greetings! Whenever you're dealing with a laptop computer that does not power up the first thing you want to do is disconnect the AC adapter from the laptop.The next step is to remove the battery from the laptop. Then reinsert the battery and reconnect the AC adapter. Press the power switch at this point and see if the laptop will power up normally.
Laptops are also prone to overheating. If the laptop powers up after it has cooled down and then fails again you may be dealing with an overheating issue. Try taking a standard can of compressed air and blowing out the ducts that supply fair to the cooling fan, as well as blowing off any "dust bunnies" or visible debris that have accumulated on the cooling fan itself.
Also make sure that the laptop is not sitting in an orientation that impedes the airflow to the cooling fan.
Jun 02, 2011 | HP Compaq Presario CQ61420us Notebook
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
My dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Feb 12, 2010 | Dell XPS M1530 Laptop
The laptop won't turn on
Hi..
This seems issue with the power supply.
If the computer is in warrenty call dell.
Thanks
Smith
Aug 15, 2009 | Dell Latitude D530 Notebook
My charge light constantly flashes orange and my C600 won't turn on at all. I hold the power button and all the lights turn off. I got nothing. Just a blankscreen.
When you say charge light, was that the battery led light that you were referring to or the power button?
If it is the battery led light, try this:
Try to power on your laptop without the battery in your laptop.
take out the battery and just use the ac adapter, if it works fine then there could be a problem with your battery.
If is the power button that is flashing orange, then try to power cycle laptop.
turn off laptop.
take out the battery and the ac adapter.
then while those are out, you hold down power button for atleast 10-15 seconds.
put back the power source and check the led again.
Apr 08, 2009 | Dell Latitude D600 Notebook
Laptop won't boot up
That shouldn't affect the laptop booting, hold down the power button for 10 seconds, it shoul boot up., if not then remove the battery and replace it. then try it again, good luck, Gym
Dec 18, 2008 | HP Compaq nc6000 Notebook
Acer Aspire 5672WLMi Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
