Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
My router has high security settings and i would like to change them to actually play with no problems on my xbox 360 and be able to go around the internet freely my router's model is CT-5361T help would be appreciated!
    Scholar:
  • 54 Answers
Hi...
here is a link where you can go ahead and download the manual of the router and check what are the different tabs in you router and how you can go ahead and change the security settings..
here is the link it is a pdf file...http://www.comtrend.com/dbase/download/CT5361T_A3.3.pdf
this has all the settings for the router and how to make a change..
before reading this find the default gateway from you computer,click on start,then run,type in cmd and hit enter,
once you hit enter click on ok,you will get a black box,in that box type in ipconfig,check the default gateway..
now open a web browser,the place where you type in the address,empty that box and without http or www,type in the default gateway once you put the default gateway and hit enter,it will tell you to put the user name and password
the default user name is root and password is 12345,it will now open the router page now you can go ahead and check the manual and see how you can choose different type of security settings...
vedhick...
Posted on Feb 16, 2009
I can not play xbox because security is to high how do i chance it
you need to give your xbox a static ip address.
on your linksys router go to internet explorer. browse to http://192.168.1.1
default login is blank password is admin
go to Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074. Go ahead and enter the settings shown above into the Port Range Forward menu.
port forward the following ports up above to the ip address that you set your xbox 360 to.
Apr 03, 2011 | Linksys WRT120N Router
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Im trying to connect my xbox 360 to xbox live but its gives me an error about eh MTU setting being to low i checked the router page but i cant find the tab/button to change it.
Sounds like a firmware problem on the router. login to the router and check the firmware version against the latest from 3com - the router should be able to check automatically.
Double check the universal plug and play (uPnP) is enabled - it should be under security settings on the router.
Dec 15, 2010 | 3Com OfficeConnect Wireless Router
Wireless Network Adapter Xbox 360 (SKWIFIX360): My wireless adaptor on my xbox 360 won't connect t...
1) Reset the router then the xbox.
2) If it still does not work, Change the security code for your wireless on your router. Then connect using that security code on your xbox.
Apr 28, 2010 | Microsoft Computers & Internet
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Jun 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Ping is high at closest server. But low at servers much further
hello there i have built many wifi networks and install networks for server hosts.
I would try setting your port forward to the correct port that xbox live runs on.
also uncheck Qos (quality of service) this will throttle bandwidth, you want this off.
Jan 26, 2009 | Microsoft Xbox 360 Console
Cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Jan 05, 2009 | Microsoft Wireless Network Adapter Xbox...
Strict nat settings
go to security tab on the router interface and deselect NAT button.
Jul 03, 2008 | NetGear WGT624 Wireless Router
Xbox 360
If your xbox is stuck in standby, you've got some issue. Unless you pressed the "standby" button on your router while playing Halo 3 at a weak attempt to try and cheat other players, and then your xbox 360 became stuck in "standby"mode, I have no idea what you are talking about. Elaborate. And if this occurred after prressing standby while playing Halo 3, you probably deserve having a broken xbox 360 since you were probably trying to cheat against me! As for the guy who's life revolves around Call of Duty, you have to stop playing sometime. Either when the console actually breaks from all the cheezy poofs and mountain dew you place on it or M$ poorly designs the xbox 360's to do this intentionally.
Apr 26, 2008 | Microsoft Xbox 360 Console
How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
Ok in order to help you resolve this issue I need more information. Is this a newly setup router? Did you setup any type of security? WEP OR WPA these are encryption tools that allow only you to get onto your network.
Nov 20, 2007 | NetGear RangeMax WPN824 Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
187 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
