Question about JVC TH-S3 System
To whom it may concern: I recently moved and am unable to locate my owners manuel. I would like to set up my DVD player to hear the audio while from the DVD player while watching TV? How do I accomplish this? John
    President:
  • 1,901 Answers
Here is a link for your user manual in PDF format.
TH-S3 Manual
Once you open it, click on "Save a Copy" and save it to your documents for future use.
Posted on Jan 15, 2009
Overhead DVD player in 2008 Toyota Sienna does not show the picture. Sound works.
Hello, I hope this helps. If no change then you probably have a hardware/ wiring issue and the dvd player may need to come out. Please advise
1. Confirm the DVD RSE system is inoperative. (blank screen) 2. For vehicles with Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Press the INFO switch on the navigation unit. B. Press the "Screen Setting" touch button on the navigation display. C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display. D. Press the DVD switch on the RSE system (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 3. For vehicles without Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Push the Audio Control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "REAR LOCK" is shown on the screen. B. Turn the Audio Control knob so the display says "OFF" next to "REAR LOCK". C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 4. If the above procedure resolves the concern, explain the system operation to the customer.This procedure is described in the Audio/Video" section of the vehicle Owner's Manual. 5. If the above procedure does NOT resolve the concern, perform RSE diagnosis using the Technical Information System (TIS), 2006 model year applicable vehicle Repair Manual.
Jun 29, 2015 | 2008 Toyota Sienna
Unable to get any audio output as Audio out / Digital audio out cannot be acivated . all settings on the Audio setup page are deactivated
Hello sir,
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Select "General" with RIGHT
  4. Select entry "Basic" with DOWN
  5. Release OSD
  6. Current RC should be displayed
  7. Press "Condition Memory"
  8. Press the button for the desired RC
  9. Press SETUP
May 26, 2008 | Marantz DV7000
I recently moved to a new apt. the owners have
You should check the scart lead bith ends tv and dvd,make sure they are fully in
Sep 24, 2009 | Televison & Video
Audio Issue
You may have tried this, but when you hook up audio out from TV to audio in on reciever, did you try the different input options for the reciever. Often times, audio in is an aux1 or aux2 setting on the receiver. If it is working with the DVD player, it is functional, you just have to get the wires hooked up and get the reciever on the correct setting. Also, even if you have TV audio out correctly configured to audio in AND on the correct input setting, the TV volume will have to be UP as well as the receiver volume. NOT ALL THE WAY UP (you'll blow your speakers), but up about 25% for you to hear it.
Jul 29, 2009 | Audio Players & Recorders
I need owner manuel to set up
http://audio.manualsonline.com/manuals/mfg/alpine_electronics/ivad300.html
you can download or print Manuel at the link above
Jul 23, 2009 | Alpine IVA-D300 Car DVD Player
Video will not work
I am having the same problem and no one has been able to help me.
Jul 07, 2008 | RCA DRC8335
I have a Pioneer DV 585A DVD player that happily plays DVDs and the background sounds seems to be fine, but on some of the DVDs you can hear the voices of the characters speaking and then on another you...
Hi edwardm1,
If you are only hearing part of the audio from your DVD player, I would suggest you check your audio settings before seeking repairs.
Audio can be encoded to a DVD in several ways. If the audio on the disc is different than the settings on your DVD player, you may not hear all of the audio layers. For example, if your DVD is encoded in 5.1 Surround Sound, but your DVD player is set only to play basic Stereo, you may only hear portions of the audio.
Try accessing the menu on your DVD player, and look for the audio settings. If there is a higher setting available than is currently selected, try a higher audio setting. A higher setting should also be compatible with lower types of audio encoding.
If this does not improve your audio, or if you need help navigating your product menus, I would recommend giving Pioneer's toll-free support line a call at (800) 421-1404.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 13, 2008 | Televison & Video
Car dvd player with cd changer
Can you provide more information? What kind of vehicle is this in? Do you hear audio when the Tuner is selected, or when you're playing a CD?
Jun 10, 2007 | Alpine IVA-D901 Car DVD Player
JVC TH-S3 System Logo
130 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
