Question about Philips 42PF9630A 42 in. Plasma Television
Phillips plasma tv blinks a red light
My tv came on then went off and now blinks a red light and will not turn on at all
  • 1 more comment
  • kellar6263 Jan 15, 2009
    pilips 42pf5321d/37
  • needmyps3fix Mar 02, 2009
    same issue- unplugging worked the first two times only
  • arelin56 Mar 12, 2009
    I had the same problem about 9 months after i purchased my tv and had to have a service tech come out. He took the tv away and after about 3 months he called me and said that Phillips had just gotten the part to him because it was a manufature defect with the power supply they were using
  • 35 Answers
Could be bad capacitors on PSB. Email me if your still interested in DIY. SW upgrade won't help you if you cannot turn the tv on.... YOur set went into protection at startup. Could be caps could be boards gysgt2u1@yahoo I'll try to help you while I search for a solution to mine....
Semper Fi
Posted on Mar 02, 2009
    Problem Solver:
  • 37 Answers
Hi kellar6263,
Try unplugging the TV from the wall for about 15 seconds. Then plug it and see if it works. There are more troubleshooting tips that are beyond the scope of what I can write out on FixYa (like upgrading the firmware on your TV using the USB port) but you can check out the Support Page for your Television.
Best of Luck
Jordan
Posted on Jan 15, 2009
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Tv went out itself red light ( power on off ) just blink, we can't turn on tv set neither fron remote or at the tv set
Jun 30, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Red light blinking
My one take too long to turn on, relay/green light on and off for hours before it can start, I use a hair dryer to heat it up everytime, aim at the center from top, then it turn on very faster, no need to service
Feb 28, 2008 | Philips 32FD9954 32 in. HD-Ready Plasma...
Philips 42PF9630A 42 in. Plasma Television Logo
366 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
