Question about Kodak EasyShare DX6490 Digital Camera
Computer not detecting camera when connected with usb port.
I am pretty sure its a registry problem, i had it connected and working fine when i first got the camera, i had a problem with computer and had to reinstall camera easyshare program, but now computer won't detect camera when connected, can you please advise me how to fix this considering its most likely a registry problem, is it possible to delete kodak files from registry safely then reinstall easyshare?
I hav the sam edamn problem wat the fuc am I supoosed to dfo fucjk all u fuckin niger and your cheesers
Posted on Jun 21, 2008
    Genius:
  • 2,985 Answers
Remove all Kodak software. Use CCleaner or similar to cleanup. Close down the computer plug in the camera, make sure the camera is in the upload position. Restart the computer Does the camera register now? Come bak here with the result.
Posted on Jun 16, 2007
I can't download pictures to my computer error message says cannot detect camera
It may be a USB port issue or a USB cable issue. Try an alternate cable or a different USB port. Try other USB devices on those same ports to make sure they work. Try using a USB card reader to transfer photos from the card directly instead of plugging in your camera directly.
Jul 04, 2012 | Canon Powershot Sx150 Is 14.1 Mp Digital...
Cannot be detect of my computer?
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Aug 27, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Not detected by the pc
Aug 14, 2011 | Samsung G2 Portable External HX-MU064DC/...
My seagate 320 gb freeagent go led is blinking and is not detected by my computer when i connect it to the usb port
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
May 31, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
My computer does not detect my power shot A400
If you camera is not detected when connected to your computers USB port what you can try here first is to connect the camera on a different USB port and make sure the connections and usb cable is fine, and if your computer is a desktop you can try connecting the the camera on the back USB port of your computer and see if that will be fine.
But if still not working I will suggest you try connecting the camera on different computer and also if possible use a different USB cable and reinstall the camera software if you have the setup disc for it.
Mar 07, 2011 | Canon PowerShot A400 Digital Camera
Hi my trancand external hdd is not detected bt my laptop --- dell inspiron 1545 --- windows vista
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Oct 11, 2010 | Transcend STOREJET 2.5 HI- SPEED USB...
My pc cannot detect the external hard drive.
then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Aug 16, 2010 | Computers & Internet
Canon powershot A720is continually powers my computer on and off
Don't thru the camera out the window as it is working on the other system.
I assume you are connecting the camera to the computer USB port; if yes, please check the USB drivers of the operating system on the computer. there might be a physical USB port issue, or USB driver issue or USB port over current issue.
Check all this things before connecting ur camera or check with any other USB device.
Regards,
k.vel
Mar 30, 2009 | Canon PowerShot A720 IS Digital Camera
Computer cannot detect camera at all!
Can you use a USB card reader? The canon software is great but it best used for using a method called tethering your camera (when you shoot directly from camera to hard drive)
Jul 15, 2008 | Canon PowerShot G9 Digital Camera
This works for Windows98
1. Uninstall the Canon camera software.
2. Search for "Canon" in the registry. Delete ALL references associated with Canon camera in the registry. Just uninstalling the software will not work. Do not delete any other references to Canon products (printers, etc).
3. Re-install the Canon camera software.
I've had to do this several times. Works every time.
Jan 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Kodak EasyShare DX6490 Digital Camera Logo
283 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
