36'' Admiral fuzzy picture model GOJ 12390
TV approximately 10 years old has good color but picture seems out of focus. Does not clear up after warms up.
    Problem Solver:
  • 5 Answers
You'll have to take the back off the tv and on your right you'll see two black button on the flyback transformer one over the other the other the top button is for the focus you can bright or darken the image on your screen don't be afraid it will not bite as long as you don't touch nothing but the button with a phillips screwdriver and don't have the kids around when you are doing it
Posted on Jul 31, 2009
I recently received an admiral tv and i was looking for the audio and video jacks/ports and could not find any... are there any ports? it is n admiral tv and the model # is GOJ 12028
If there are no A/V jacks on the set you can get a RF modulator. They are cheap on Ebay and work great. All you would do is plug in your A/V plugs into the RF modulator and then plug in a coaxial cable on the output of the box then plug the other end to the input coaxial cable jack on the TV. Make sure your TV is on the channel your RF modulator specifies.
Aug 31, 2012 | Televison & Video
I have a Toshiba 36"
Resolders the FBT-(flyback tranformer).Resolders the video board connections sockets holes,that the board connected to the CRT-(tv tube).Plug in the tv,to have power to the tv,take out the tv video board,for exposer of the CRT-(tv tube).Take an electrical wire with a good insalation in it,grounded to the tv steel frame some where.Take the other end of the wire go toward the open high voltage CRT-(tv tube).U will hear a pop sound,than ur tv CRT-(tv tube) is a 100% clean out of contaminations or u will hear a deeing sounds only,mean the tv CRT-(tv tube) it is to old to pop anymore,just let tv deeing sounds going on for like about 20 mins to rejuvenated the old CRT-(tv tube).After this repluging the tv video board for a tv signal and readjust the button on the FBT-(flyback tranformer) that said focus to fix the CRT-(tv tube) focus problems.
May 01, 2011 | Toshiba 36A40 36" TV
Fuzzy picturethe
If the colors appear to be aligned and the only isue is focus, than you can adjust the focus on the flyback transformer. Carefully remove the rear cover and locate the flyback transformer (part with large red wire coming out the top). There should be 2 controls/adjustment points on it. One is for screen and the other for focus. Try adjusting the focus using a mirror to see the front of the set. You should adjust the control back and forth a ferw times to "loosen" it up a bit before settling down to the focus point.
Update this with the results.
Dan
Nov 30, 2009 | Zenith R57W46 57" Rear Projection...
Tv won't turn on
I donot know the model # but if it is 11 years old, it is the classic we have a lot of bad caps. If the fuse is good, this is all you need. Maybe 10 or 15 of them can be found with the cap check. If the fuse is burned, replace the H.O.T., the poweline reg. and that small voltage reg just two inches away. [other side of heat sink] See the NTE cross ref bible for semiconductor replacement. The resistors are usually good. Caution High voltage inside!!!!!!!!!!
Sep 03, 2009 | Zenith Televison & Video
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Fuzzy Rear Screen Projection TV
Probably the EHT unit is failing or the Focus Control is out of adjustment or if it gets worse as the brightness increases, may need a new TV.
Apr 02, 2017 | Televison & Video
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Black border
u are have a horizontal problem. seek pros help
Dec 25, 2006 | Panasonic CT-36G34 36" TV
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
