Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Printing labels is a pain! It is much easier to print using an A4 sheet with (say) 7 rows of 4 labels on.
I suggest you use the Ricoh support site
http://www.ricoh-support.com/Enduser/support/
To find your WiFi password, locate your Wireless Access Point (Might be built into the Modem) and look on the underside if it. There will be a lable saying "WiFi name", "Passphrase" etc. That Passphrase is the WiFi password.
You can control the format of your print-out via your Windows Printer properties (e.g. in W7: Control Panel -> Hardware and Sound -> Devices and Printers -> Printers and Faxes section -> Double click on Printer -> Pinting preferences) : under Preference/Features - 'Color Options' should set to 'Print in Grayscale'.
don't know if you got it fixed or not but can give you mine....if your looking at it from the top it goes like this....in the twelve o'clock position nothing,1 o'clock is recirculate then 3 o'clock is backwash then 5 o'clock is close then 6 o' clock winterise then 7 o'clock is waste then 9 o'clock is filter then the 10 or 11 o'clock is rince. hope that helps..
You need an updated driver that works with Windows 7. Go to the following link, click "Software & Drivers", then select "Windows 7" from the drop down menu. You will want to install the first item on the list for networked printing, or the second item if you don't need networked printing.
