I have a Ducane fits all 92 my lanlord installed,about 3 months ago.The thermostat is a new digital. The temp is set on 68,and if i go to 72 for example,the furnace starts and runs fine for about 3 to 5 minutes.The burner shuts off,the blower continues to run,And the buner tries to relight,and it fails to do so.The only way to get the furnace to run again and blow hot air is to shut the system off and restart.
  • Randy Hough
    Randy Hough May 11, 2010
    What brand is the thermostat?
  • 3 Answers
Sounds like you are not proving flame to me. Could be a variety of things. I think it may be the board...but that is a guess from past history with Ducane
Posted on Jan 17, 2009
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
Installed June 12, 2012 a new Ducane Bottle Gas Furnace. My furnace will run a normal cycle of around 10 to 15 minutes. Then 3 min later it will start again and run for 3 to4 minutes and shut down or
1 do you have a program or mercury buld mercury bulb.is usally a adjustable heat anticipator which a digital is fixed I recommend a digital t stat but also be advised that mercury bulb tstat are really phased out you could also have a issue with your main limit inbetween the heat exchanger wheather it is a cam stat or a normally closed limit but being a new furnace its more likely to be a n/closed limit will open if there is to much heat in supply box above the evap coil.you would need to take your delta temp reading within manufacture specs..or call aca or your local hvac company 770 932 8990 ask for mr.blaine to schedule your appointment today or are office staff thanx.
Jan 24, 2013 | Ducane 30400042 (LP)
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Ducane model number 30400040 just received set of (3) stainless tubes to replace the old ones whats the easy way to install
goto ducane web site http://www.ducane.com/manuals/
and download manual. They have Meridian and Stainless models in 3 & 5 burner for LP & NG. Follow 1 year cleaning instructions. Pictures and instructions.
Apr 05, 2010 | Ducane 30400040 Stainless Steel Grill
When out temp is below 50, heater does not produce enough heat
Sounds to me like the thermostat or thermostat wires are wrong.
If you open the t-stat make sure no bare wires are touching one another.
Typical wire codes/colors are red to R,green to G,yellow to Y,w to white or w1,orange to O,blue to common(C),brow to E.
These should be the same in the air handler as well as the outside condensing unit.
Some installer may use different colors for some other reason.
Verify these colors throughout and report back.
Has the problem existed for the 2.5 years or is it recent?
Feb 18, 2010 | Ruud Central System Air Conditioner
Have a 1004fa model to heat a room. temp on
You may have a bad circuit board. Depending upon the age of the heater it may still be under warranty. Contact Rinnai (in US) 800-621-9419 with your serial number and installation date. Ask if they can offer a solution. Good Luck!
Jan 13, 2010 | Rinnai Heating & Cooling
I have a hotpoint ice diamond fridge which has begun to freeze its contents, even on lowest setting. I replaced the thermostat 3 years ago and again 18 months ago due to the opposite problem of not cooling...
it is the thermostat . the problem occurs when installing the thermostat the small pipe must not bend more than 45degrees. the point of application on the evaparator plate that makes cold is it tight fitted there
May 13, 2009 | Refrigerators
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Neff u1721fan oven element has been replaced 3 times in two months
is it the right voltage?is the new element screwed tight when fitted?they should last alot longer than that--Ire close bye.
Nov 26, 2007 | Neff U1721 Double circotherm Electric Oven
Heating & Cooling Logo
208 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
