Question about LG WM-1832C Front Load Washer
I have LG WM1832CW washing machine. It is having problem now. The water comes out from the drain bump filter right away during the water filling cycle. I also tried just put the water into int drum without turn on the power. Same problem. How do i fix it?
  • Anonymous Jan 15, 2009
    The water is from the drain bump filter which locates at the left bottom of the front side during water filling cycle. The drain hose at the back is dry. I also tried this: without turning on power, I opened the front door and put some water into the drum. The water comes out from filter right away.
    Scholar:
  • 58 Answers
Your drain hose is in the drain tube to far, pull out the hose and only put it in about four inches into the pipe. when you drain line is in to far the hose get a syhpon effect from your sewer.
Posted on Jan 15, 2009
Own a lg wm1832cw front load washer doesnt seem to clean properly when wearing tee shirts for an hour smells like they never were washed paid alot of money for this thing seems cheaper top load machines...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Sep 12, 2011 | LG WM1814CW Front Load Washer
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
Lg wahser wm1832cw flashes oe on readout. nothing in drain
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Aug 25, 2010 | LG WM-1832C Front Load Washer
LG wm1832cw filling slowly
The water valves might be going bad, or there is a clog in the hoses. Also check the water pressure going into the washer.
Dec 03, 2009 | LG Washing Machines
I have the LG WM1832cw washer. Something is wrong with the cold water fill. Not the hot water just the cold water fill valve section as it fills VERY VERY SLOW (water trickels in). Hot water fills fast! I...
Is resistance between each terminal of INLET
VALVE ASSEMBLY 0.8~1.2 kω? If not replace it.
Is the inlet valve filter clogged?
Clean the filter.
Verify the voltage of the inlet valve connector is
120 V AC. No voltage? Check electrical connection.
Replace the MAIN PWB ASSEMBLY.
I have an LG training manual which might not be the exact one you need but it gives an idea what to look for.
LG WASHER REPAIR MANUAL
Post your model number at any of these
fine forums for an answer
that will save you big money::
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
NEW! http://sublimeforum.invisionplus.net/
Nov 10, 2009 | Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
LG WM1832CW water leaking
your valve is not closing or your cycle isn't reading correctly. there should have been a diagnostic read process that should have came with the machine. if not you may have to end up buying a new drian assembly
Jan 15, 2009 | LG WM-1832C Front Load Washer
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Jul 08, 2008 | LG WM-1832C Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG wm1832cw Washer IE error
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. When u hav rinse problems, it is usually the outlet filter.
Sep 11, 2007 | Washing Machines
LG WM-1832C Front Load Washer Logo
144 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
