Question about Whirlpool Duet GHW9150P Front Load Washer
Can't get door opened. model #GHW9150P
I TRIED UNPLUGING FOR 5 MINUTES AND IT WILL NOT UNLOCK. DO YOU HAVE ANY IDEAS ? IT SHOWS "F" AND THEN "dL" ON THE LED. THANKS, MITTLERS
  • rgalper412 Jan 15, 2009
    I have the same problem right now with a 4 month old whirlpool duet. I find this problem to be dangerous. What is something is in the washer that shouldn't be. Such as a pet!! Cat! Now I haven't experienced this but you should have some safety ability to open the damn door!!!!!!
    Sergeant:
  • 311 Answers
The f represents failure and the failure is dl door lock .if i was there as a repairman i would inspect the wiring from the door lock assemblie to the [ccu]computer console [the button area you push to start]also inspect door lock assemblie and the computer.if looks normal i would replace the cheapest part first[but not the wiring if inspection ok]so thats the door lock assemblie.you can unlock door by removing bottom front panel and feeling up in the door lock area ,their is a tab to pull down,then door will open.to replace door lock assemblie you go thru tub boot area by door latch. hope that helps God bless ,tom
Posted on Jan 15, 2009
I have problem with the washing machine.it wont start and I cant open the door after I closed.it shows the sign (dL)F
its the door lock, you can turn the power off, and there is a video on utube on how to fix it https://www.youtube.com/watch?v=_BsaIsSlxNY
Apr 14, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My duet model ghw9150pw4 washer has an error code of DL F, what do I do?
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Oct 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Programme froze how to unlock it
open door and you'll see model number,send it,try unpluging dryer for five minutes to reset board
Nov 08, 2009 | Dryers
Error Code F11
TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Start and after few minutes show "dl" f
easy fix, door lock failure, replace door lock asm. on old duet this part is same as GE, and samsung parts. new duets differ
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire model 316065301 electric door locked
Try unpluging your oven for 5 minutes. It should reset it's self. If not you might need a knew door lock sensor.
Jan 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GHW9150PWO Whirlpool duet
take bottom panel under door off there 3 screws you 'll need a star tool reach on the right hand side there is a yellowgreen strap pull it and door will come open
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
