Question about Bunn GRX-B Original 10-Cup Home Coffee Brewer, Black
Bunn GRX-B 10 cup coffee brewer kicks breaker when we turn it on
Just purchased coffe pot today.
Filled with water
Plugged in and it kicked our breaker.
Tried different plugs, same result
  • 131 Answers
If you just bought this brewer, ask your retailer if they will replace it. if not, you can get ahold of the bunn warranty department in your country. they will give you instructions on getting a replacement. This brewer has a dead short in it.
Posted on Feb 13, 2009
My Neptune Top Load fills the water, the motor doesn't start.
If i understand correctly you are stating the breaker shut down which means the house breaker for the outlet power kicked out. You might try plugging something else into the outlet to see if it also kicks out, say a vacuum cleaner of a drill.
You need a amp clamp to test for something shorted or grounded (or ohm out windings) which requires trained service........you do not want to get a shock
Jan 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Why does the plug loosen and my coffee is cold after pouring???
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers Good luck. bobbyone
Dec 13, 2009 | Faberware FCP240 Coffee Maker
No green light when plugged in
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
i
Aug 06, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Maytag atlantis Top loading washer
it sounds like a bad lid switch.
Apr 07, 2009 | Maytag Washing Machines
Coffe residue inside coffee pot
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
Jan 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Keurig B60 makes coffee at random all by itself
Try plugging it into another outlet, preferably one on a different circuit breaker. If this works call an electrician. I have seen electronic devices do all sorts of strange things when the power is bad.
Mar 02, 2017 | Keurig B60 Coffee Maker
Briel Sintrac cofee/express machine
I all ways have a good coffe(express)until now.Sems to me to much water and the coffe is no good
What can i do?
May 27, 2008 | Coffee Makers & Espresso Machines
Cuisinart Coffe Maker has no power
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
204 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
